Ok, back to the wiring stuff...
Now a disclaimer...I don't have a damn clue how hurd electrons. I struggle with it more than anything else when it comes to bikes.
So keep that in mind...:D
At first I thought I wanted to control the 3000 lumen CREEs independently and I tried to reflect that in this pic.
I was utterly stalled at this point and had to rely on Steve to help wire this system up.
The System:
A. One HID headlight
B. Two CREE LEDS
C. Two HID PIAA 910's
D. GPS
E. Internal tank bag LED light
F. Gerbing heat
G. CPAP charging system
H Oil sight glass LED
I. Tank bag power
J. J&M Motorcycle CB
A fairing mounted LED controlled via a commandeered OEM heated grip switch.
All through the new switch panel and a Eastern Beaver 8 position fuse block.
What gets switched?
What doesn't get switched?
Where and how to snake the wires through the bike?
What can double up?
Where to mount the 3 HID ballests?
Where to mount the 50W resistors?
These pictures cannot capture the angst, trial and error, soldering, cutting, testing, re-cutting, pulling apart, putting together, blown fuses and burnt fingers!
Main lining 24 volts HURTS! :eek1
