Author Topic: Adding Fork boots, work-around?  (Read 9658 times)
Offline tsbt
« on: July 12, 2012, 11:01:49 PM »
Is there a work-around for putting fork boots on, or an 'easy way'? Thinking I could hang the brake lines/calipers for less reassembly :hmm:
92 K100RS 4V
75 KE125
Re: Adding Fork boots, work-around?
« Reply #1 on: July 12, 2012, 11:21:09 PM »
Just let them hang by the brake lines.  I know people get all hot and bothered and say you shouldn't but I've always done it like that and never had a problem.
« Reply #2 on: July 13, 2012, 12:29:36 AM »
or the REAL easy way, get 2 Rancho RS1952 Shock Boot from Amazon ($3.29 ea), slit them up the back and slip them on.  I cut off one end that was a little narrow.   :yes :yes
Offline tsbt
« Reply #3 on: July 13, 2012, 07:17:31 AM »
Thanks FD. Think I can pull the wheel off with the calipers on and slide the forks out?
Thanks Chaos, got some decent boots from Duck I'd hate to ruin. But at 3.29 each you could have fresh ones every week!
92 K100RS 4V
75 KE125
« Reply #4 on: July 13, 2012, 07:43:07 AM »
I did the same thing when I put boots on the '97 the first time. Slit them up the back side and used a leather punch for some holes and used small black zip ties to "lace" it on.
Had the 2nd set waiting..................  I put them on just this summer when I had the front end apart for steering head bearings.
Offline enb54
« Reply #5 on: April 23, 2015, 02:29:09 AM »
I know this is an old thread, just ordered two of those Rancho RS1952 Shock boots, looks like the cheapest solution to keeping my K75 forks clean... just sayin'...
  • Red Deer, AB
Eric
Then-1966 Suzuki X6 Hustler, 1987 BMW K100RS, 1997 Suzuki GSF600 Bandit, 1991 BMW K75 RT
Now-1974 Honda CB125S, 2015 Honda Grom (MSX125)
« Reply #6 on: April 23, 2015, 06:59:30 AM »
Just a tidbit to remember, if you put them on whole, make yourself a hole at the bottom to allow any moisture/oil/water to drain out(should there be any in there).
If you have the top portion snug/tight around the fork, leave yourself a couple small holes(on the back side out of sight is best) for air equalization during fork operation..... the single drain hole might possibly be enough, but I put one at the top end as well.
Offline enb54
« Reply #7 on: April 23, 2015, 10:58:51 AM »
Thanks for that tidbit Scott, I'll be doing the equalization and drain holes, had been wiping the forks off after every ride, but starting worrying and thinking more and more about seals, hence the fork gaiters. These (Rancho RS1952) shock absorber boots seemed to be the most cost effective solution for our type of riding...
Eric...
  • Red Deer, AB
Eric
Offline beemuker
« Reply #8 on: May 06, 2015, 12:21:23 PM »
Eric...
better hurry, they are now $3.99
  • Panama City, FL
Offline enb54
« Reply #9 on: May 06, 2015, 07:12:38 PM »
I got them already, but had to pay about $10 each for them via a Canadian supplier in Vancouver, when we go to Montana this summer I'll likely get another set for $4 each... :(
  • Red Deer, AB
Eric
