Author Topic: replacing front brake lever?  (Read 4248 times)
gohabsgo k75
« on: July 05, 2012, 04:23:25 PM »
So, what is involved in replacing the front brake lever on a K75?  I'll read up in the shop guide but does anyone have any gotcha's that are not mentioned in the book?
I assume that the brakes need bleeding afterwards?
Larry
Re: replacing front brake lever?
« Reply #1 on: July 05, 2012, 05:23:45 PM »
1. Undo the nut at the bottom end of the pivot bolt.
2. Remove the pivot bolt.
3. Remove and throw away the bendt lever.
Do it all one more time, in the reverse order (but don`t throw away the new lever)...no bleeding required.
Put a small dab of grease at tip of the lever where it meets the piston, and in the hole for the pivot bolt.
Inge K.
« Reply #2 on: July 05, 2012, 05:30:51 PM »
Recycle the old lever. Save the planet.  :deal:
gohabsgo k75
« Reply #3 on: July 06, 2012, 09:22:45 AM »
Thanks.  That is scary simple.  Simple engineering at its best, eh?  Sorry for asking such a simple question.
Larry
