Author Topic: Best Spark Plug Wires according to Red  (Read 10377 times)
Offline tsbt
« on: July 05, 2012, 10:30:34 AM »
Mystic Red raves about Magnecor wires :2thumbup:
Their catalog for my 92 K100RS4V points me to:
1995-1989 K series (except K1200), 4 cyl. 16 valve engines 40210 47210 45210 (these three numbers represent 8mm, 7mm, 8.5mm (K85)
Does anyone know which of these three sizes I need?
92 K100RS 4V
75 KE125
Re: Best Spark Plug Wires according to Red
« Reply #1 on: July 05, 2012, 10:38:48 AM »
Any of those would work.  The first two digits indicate the diameter. (and color)
40=8mm(blue)
45=8.5mm(red)
47=7mm(black)
Best price I've found is at Alamo Motorsports.  Not listed on the site but if you call cust. service with a part # they will get them for you.
Offline tsbt
« Reply #2 on: July 05, 2012, 12:49:55 PM »
40=8mm(blue)
45=8.5mm(red)
47=7mm(black)
Thanks Doctor D, I'm on it!
92 K100RS 4V
75 KE125
Offline NCJ
« Reply #3 on: July 22, 2012, 08:25:07 PM »
Any advantage to be gained by using the larger diameter wires other than a fuzz less resistance? I'm getting ready to go through my K75 and plug wires are one of the items in consideration.
'92 K75RTA - Koenigsblau
« Reply #4 on: July 22, 2012, 09:35:46 PM »
Quote
9. Do I need an 8.5mm or a 10mm size wire if my original wires are just 7mm (or smaller) ?
If you don't intend to upgrade your vehicle's original ignition with a high-output ignition, you may not need larger size wires. Magnecor KV85 and R-100 Race Wires have been designed primarily for race engines that will be run with high-output ignition systems, and contain high-capacity 2.5mm conductors that require extra insulation when used with extreme-output ignition systems. Magnecor Race Wires will also be exposed to heat an unmodified production vehicle will never experience. However, the major advantage Magnecor Race Wires have over conventional 5mm, 7mm and 8mm wires is that neither the high-capacity conductor nor the insulating jacket will wear out during the life of the engine.
« Reply #5 on: July 23, 2012, 08:01:54 PM »
Welcome Jay.  You have the same motorcycle as me!  How long have you had it?
Offline NCJ
« Reply #6 on: December 16, 2012, 03:22:23 PM »
Since the summer of '97, so 15+ years; only a tad longer than it's taken to reply to your post..... :dunno2: :yes
« Reply #7 on: December 16, 2012, 03:55:53 PM »
I run the 8mm ones in my K75 - mostly because I wanted the blue color.
« Reply #8 on: December 21, 2012, 10:50:06 PM »
Red is always faster.
Offline Dragwn
  • MFP Gosling 1
  • Guinness for Breakfast
« Reply #9 on: September 23, 2014, 06:52:03 PM »
1985 K100rs
2000 Kwaka ZRX1100
