Author Topic: Bit of Dirt and Grime inside some threads, start over?  (Read 9323 times)
Offline tsbt
« on: June 29, 2012, 11:11:32 AM »
Morning fellow Bricks,
Question: Finally reattached my engine covers and timing cover after replacing the Front Seal. Cleaned the bolts off, coated them with anti-seize and torqued the cover on accordingly, however I heard a bit of dirt crunching in the threads on a few. Should I pull it off, clean them out and start over?  :tongue
92 K100RS 4V
75 KE125
Offline Opus
  • 1988 K100 LT
Re: Bit of Dirt and Grime inside my threads, start over?
« Reply #1 on: June 29, 2012, 01:54:31 PM »
I.M.O.
I would do it over.
But my Dad was a Mech. and would head slap me if I did not clean it out... :nono
But that is just me...
Toney
Offline tsbt
« Reply #2 on: June 29, 2012, 04:15:56 PM »
I.M.O.
I would do it over.
Consider me 'head-slapped'  :giggles
92 K100RS 4V
75 KE125
Offline motodude
« Reply #3 on: June 29, 2012, 04:34:32 PM »
I.M.O.
I would do it over.
Awe, the joys of child ownership!
Tom
'95 K75RT
'90 K75RT
'87 K100RS Motorsport
Offline tsbt
« Reply #4 on: June 30, 2012, 08:51:18 AM »
Which also begs the question, how best to clean them out? So far ive used an Awl with a rag, some gasket remover, a chisel to shave off old rubber bits and sludge, qtips with a touch of break fluid on them shoving in than pulling out (not so successful), screwing a clean bolt in and out a few times...any others?
92 K100RS 4V
75 KE125
Offline DRxBMW
Re: Bit of Dirt and Grime inside some threads, start over?
« Reply #5 on: June 30, 2012, 09:05:45 AM »
Hope like hell, you R&R the cover "rubber bushings" as part of the job.
Once they get old & hard they lack the proper compression, hence a oil leak.
Go EASY when torquing the cover bolts. I've seen first hand DYI motObrick wrenches strip them. (bad)  FWIW, antiseize may NOT be a good idea being such a low torque value. 5.9 foot pounds for reference. Antiseize CHANGES the that value BIG time compared to a dry thread !
New bushings are the key to tight seal !
I use kerosine and toothbrush for cleaning the threads on the bolts.
Gary
Williamsport,Pa
1994 K 75 ABS "custom"
2005 F 650 GS
Offline tsbt
« Reply #6 on: June 30, 2012, 10:33:15 AM »
Thanks Gary, was meaning to get Kerosene, only anti-seized the timing cover. Cam and Crank went on dry, with a touch of oil around their gaskets. Guess new bushings are in order too. Assuming R&R means remove and replace the bushings on the engine bolts, and not rest and relaxation, which judging by this summer weather and a few cold ones in the fridge, it means both.   :hmm: :2thumbup:
92 K100RS 4V
75 KE125
« Reply #7 on: June 30, 2012, 12:39:55 PM »
How about some of that "compressed air in a can" with the plastic nozzle on it for direction control.....
You know, the thing you use on your computer keyboard to keep the crumbs out from under the keys....
Offline tsbt
« Reply #8 on: June 30, 2012, 12:51:58 PM »
Got it. It works a charm for about 10 seconds then freezes, a decent air compressor would be nice right about now. The tool wishlist grows :deal:
92 K100RS 4V
75 KE125
