Author Topic: new Abs light query  (Read 6524 times)
Duc750
new Abs light query
« on: June 27, 2012, 06:46:40 PM »
Hi Guys a new one for me tonight having just pout a new ABs II modulator in the bike tonight (well new to me and its off an r1100r but the same part no) I've got the alternate lights. So I reset it (several times as its showing a front sensor fault. Can get the lights to both stay on but not fals in unison. Ok so its gettong dark on the door step so I start the bike up to ride her into the garage and continue playing. As I ride away the Abs tries to self test but doesn't clunk and both lights come on solid with no flash, any guesses?
Re: new Abs light query
« Reply #1 on: June 27, 2012, 06:51:02 PM »
The R and K ABS II brains, although they have the same part number, are programmed differently.  You need to take it to a dealer who knows what they're doing to get it reprogrammed for use on a K.
Duc750
new Abs light query
« Reply #2 on: June 27, 2012, 06:54:33 PM »
I did wonder, it'll be ok to use in Abs faulted mode thoiugh won't it until I can get to the dealer?
Sent from my BlackBerry using Tapatalk so excuse the spelling!
« Reply #3 on: June 27, 2012, 07:02:00 PM »
It'll be just like a non-ABS bike - with an annoying flashing light.  Hitting the ABS switch will make it stop flashing for about 5 minutes, then hit it again when it starts flashing again.
« Reply #4 on: June 27, 2012, 08:18:36 PM »
And then you get out the black electrical tape and make it go away.  (cover the light)
« Reply #5 on: June 27, 2012, 08:36:47 PM »
Duc 750, check out "ABS 2 difference between models" Here.
Inge K.
Duc750
« Reply #6 on: July 03, 2012, 04:18:40 PM »
Just as an update to this - Our local BMW dealership has found they still have a GT1 in a cupboard and are going to plug it in and see if it works. Its one of the range of tools they were instructed to destroy a few years back when the new systems came in. The new systenms won't even read the fault codes on ABS II !
Luckily a few of the older techs in this dealership are proper mechanics and veritable squirrels so have spirited away a lot of the old tools they used to use for a rainy day!
As long as the GT1 works then we should be good - otherwise I'll switch the computers across and see how that goes
