Author Topic: Preventve maintenance on the fan?  (Read 6231 times)
Offline ljjohns
« on: June 23, 2012, 12:11:24 PM »
Joel also noted, in his most recent test of our 95K11, that his thighs were burning.  That probably can be fixed by a Johnny blanket.
But he was also wondering about the fan, and has proposed pulling it, cleaning it, and lubricating it.   I wasn't able to find anything on "preventive maintenance" on the fan: is it worth the effort to pull the fan and attempt such preventative steps?
  • All in El Paso, garaged in my house, my wife's house, and friends' houses
  • 91K75RT, 95K1100LT, 96K1100LT (restoration project) 2003 K1200LT
Larry Johnson
El Paso TX
Re: Preventve maintenance on the fan?
« Reply #1 on: June 23, 2012, 12:26:38 PM »
Main thing to do is make sure it runs occasionally. Let it idle after a ride if need be.
Offline orforester
« Reply #2 on: June 23, 2012, 12:32:50 PM »
Ducker probably has teh answer, but turning the fan once in a while is good prevention.  Mine had fried the brush holder, so I am not sure if there is any more prevention, except turning the fan or allowing it to run occassionally.
Taking the fan apart is a major deal, hoses, fairings, anti freeze, etc.  Best left to Spline lube days, when everythign is already off.  JMO
Bob
1989 K 100 RS se (SOLD)
1985 K 100 RS, now RT
2008 R 1200RT
« Reply #3 on: June 23, 2012, 12:35:50 PM »
This.  Otherwise corrosion will build up and seize it.
Offline GWHayduke
« Reply #4 on: June 24, 2012, 07:16:28 AM »
The fan does cycle on and off, but sounds as if it's chewing up a bushing or bearing.
Head wrench and kibitzer for:
R1150RT (mine)
K75RT (Larry's)
3 K1100RTs (Larry's)
« Reply #5 on: June 24, 2012, 07:32:26 AM »
Loose fan?........rubbing against the radiator.....have happened before.....result radiator leak.
Inge K.
