Author Topic: The Brick of the Corn Projekt  (Read 48578 times)
« on: June 23, 2012, 12:31:40 AM »
the new to me blue chee curd motobrick... aka the brick of the corn...
14k rs with tior dot date 8th week of 2001... 12 years old and looks new... yawl... tomorrow new michelin pilot road 4s + steel valve stems + tire gard...
22l with all the necessary ch1t...
rbr lightbar new old stock...
catz xlo ambers... yawl...
multivario tankbag new old stock...
blue glafer brake lines...
windshield switch for the audivox cruse...
gonna be a busy day...
gotts more ch1t on the way... and boxes i aints even opened yet...
more later...
o... bye the way... it started like it was ridden yesterday... first push straightaway without hesitation and it endured the wisconsin winter not being started since december...
the only moto better than the rs motobrick is the h-d super glide t-sport... which i will have in the garage by the end of next week...
if you aints gotts a tire gard you should...
10wt is the what the motobrick wants...
dash ppwerlet...
a proper work area minus a lift... im thinking about it...
going with metzeler me880 vr rated radials... the same old name but now in a single compound radial for heavy motos...
gotts to getts some snake oil in there...
im gonna run 2 bottles through in 4 consecutive tanks...
after i replace my brake lines im gonna do a full on bleed...
signal dynamics leds for the bung...
should have it buttoned up tomorrow...
i will not be posting a photo of my extremely rare catz azzure white 4700k 55/60 headlight lamp...
Offline sh00ter
hey jo - is this the tps you mention
http://www.amazon.com/Show-Chrome-WIRELESS-PRESSURE-MONITOR/dp/B001VDUBHW
also - shouldn't ou have a bottle of dot 4 there? not 3?
where's the best place to get the brake lines, those look snazzy; i'm always up for another diy upgrade
she is sharp!
'94 1100 RS
greetings ch()()ter...
thats the one... what i do is install bikemaster metal valve stems and velcro the unit to the speedo... ill get some photos up...
its not waterproof so the unit has to be removed from the speedo in the wet...
i got my tiregards on sell at year end clearance sales... they generally run about 120 $ to $130 year end...
i drink dot 3... its good for my complexion and keeps me regular... i use dot 4 in the r s motobrick...
from what i hear the galfers are f ed up... i shall see when i get them on... im thinking spiegler may be the way...
I'm a fan of Spiegler, I recommend them.
splinal lube... mini adjustable... i use it as a tork wrench... you know that swing arm is sensitive...
works performance...
run n lites...
calling it a night...
more later...
more later...
Offline sh00ter
the first burger on the new virgin brick?  How was it - did it have that freshly upgraded new brick taste?
'94 1100 RS
white castle double chee... they were wonderful... all of them...
i heart the white castle double chee... its the worlds most perfect food... im gonna dehydrate a few hundert of them for my doomsday bunker...
Offline Photog
From some of the other pics, I wouldn't have thought you were a White Castle fan.
My wife figures they must be an aquired taste, but I grew up with them, so I guess they are part of my dna, still like them when I can get them.
  • NNE
  • K75-S
greetings photog... i grew up with white castles too... i may have to ride to minneapolis just to score a of double cheee...
all my work here is done... and now i must ride... ride into 100+ degrees and 80 + humidity in search of catfish cheeks and twisty river feeders flanked by motobrick roads...
when its hot i drink lotts o water and generally pizz myself on a regular basis... for this ride i gott the extra large can of pledge... gonna spray up the taint region real good and see if it beads up the pizz and keeps it rolling down my leg... better to have pizz foot than monkey taint... we shall see... i will be doing a photo expose for the lieberry to be posted at the conclusion...
yeeeeeehaaaaaaa...
more later...
Is Port Washington anywhere near Fond du Lac? Can't find it. :dunno
been rolling in the catfish hole... its 107 here in the hole... scored a room for some ac... drank  11/2 gallons of water so far... now im off to the pikes peak river lookout for some yeeeeehaaaaaaa...
when i discovered i was in iower and didnt remember crossing the bridge... i decided to gett a iower pork tenderloin sandwich...
tomorrow another 500 miles and some fried catfish cheeks...
its working so far... no monkey taint...
its a 4 step process... spray the seat... spray the pants... spray the unders... spray the taint...
and like majic... no monkey taint...
Offline BobZ(IL)
Aha...it does work for monkey butt!
  • Bourbonnais IL
'93 K1100LT
'78 R100S
'05 R1200GS
Lemon clean! Keeps your taint pennies to maintain.
pennies to maintain... motobrick of the corn...
past 2 days 1000+ solo miles and counting in 100+ temp 70+ humidity...
more later...
i drank nearly 3 gallons of water yesterday... you know what that means... yawl...
this ma n pa sold out the the kidd... the sysco kidd... f ing disturbing...
the hottest i saw today was 113 degrees at 57% humidity... i gotts to say it was the most miserable combination of temperature and humidity that i have ridden... this ch1t is debilitating...
back at the barn at noon today... i conclude there is some good riding in wisconsin... gonna chill the rest of the day and plan a two day assault on northern illinois and southern wisconsin beginning at 1st light tomorrow... drank 3 gallons of water yesterday... the weather here is hellish... tomorrow its only supposed to be 90 compared to 110+ of the past few days...
lotts of chip coating going on... not chip sealing like im used to... this method is laying down an adhesive oil base then putting down the rock chips then rolling it so it sets into the adhesive goo... then thats it... no top coat of goo... no yeeehaaaaaa on these newly chip coated roads...
little jersey says hi...
catfish...
over n back...
more later...
