Author Topic: Oil on clutch comming from clutch push rod?  (Read 4163 times)
Offline Micky77
« on: June 17, 2012, 02:37:37 PM »
I replaced the engine to clutch seal and o-ring along with new clutch about 500 miles ago.  However now I am getting oil migrating down the push rod shaft to center of clutch.  When I took the boot off the push rod a lot of oil came out (1/2 to 3/4 cup).  I understand there needs to be oil to lube bearing set at rear end of push rod, but should it be submerged?  Is there a drain port back to tranny basin somewhere? I plan on replacing the push rod seal, but am concerned about of quantity of oil behind the boot!  Any comments appreciated.
Re: Oil on clutch comming from clutch push rod?
« Reply #1 on: June 17, 2012, 02:56:03 PM »
Quite normal with oil in that spot, did recently post a drawing in your thread at k11og forum.
A bit easier to understand, when you see how this and that is placed in relation to each other......I think.
Inge K.
« Reply #2 on: June 17, 2012, 03:12:19 PM »
That seal at the back of the pushrod can be a PITA to get out as it is in there VERY tight.
Use a socket of just about the same diameter to pound the new one in.
