Author Topic: drip,drip.....  (Read 6514 times)
jeffhestand
drip,drip.....
« on: June 12, 2012, 08:35:08 AM »
I am at my wits end trying to get my final drive to stop leaking. I changed the lube to full syn and think that might have contributed to the problem. I have got a new nut and a new 14 mm aluminum crush washer and it still drips. Is there a seal back there that could be causing the problem and i just think its the nut??? HELP!!!
Offline motodude
Re: drip,drip.....
« Reply #1 on: June 12, 2012, 09:26:51 AM »
I don't know where you're seeing the leaked lube, but there is a large seal "behind" the brake rotor.  It is not too expensive (under $30 if memory serves) and you can replace it yourself.  There are instructions on how to do it here and on the ibmwr.org site (http://www.ibmwr.org/ktech/final-drive-seal.shtml).
Make sure it is this seal before replacing it.  They don't go bad often but they do sometimes.
'95 K75RT
'90 K75RT
'87 K100RS Motorsport
Rick G
Re: drip,drip.....
« Reply #2 on: June 12, 2012, 10:18:01 AM »
Motodude is spot on about the big seal but before just replacing it be sure the bearing isnt worn and loose. It doesn't happen often but checking it will save having to do it all over again and it is easy to just give the disc a wriggle to feel and play.
jeffhestand
Re: drip,drip.....
« Reply #3 on: June 12, 2012, 11:05:42 AM »
thanks. I still have yet to finally determine ( by watching) where it is leaking. I just cant imagine with a new drain plug and a new alum crush washer that it would continue to leak there. I guess with 68K the seal could be leaking. Ugh.... thanks
Offline motodude
Re: drip,drip.....
« Reply #4 on: June 12, 2012, 01:14:38 PM »
I would almost guarantee, it is not the drain plug (w/ new crush washer).  Feel "back" between the final drive and the rotor and see if any lube is back there.  That would be a decent indication that it is the seal.
Tom
'95 K75RT
'90 K75RT
pjjj3386
Re: drip,drip.....
« Reply #5 on: June 17, 2012, 07:04:40 AM »
I've been dealing with the same issue for a while. Just kept an eye on the oil level and added small amounts about every 2 weeks. Now it seems to have stopped leaking. Could it have been overfilled?
jeffhestand
Re: drip,drip.....
« Reply #6 on: June 18, 2012, 03:37:58 PM »
i am kind of wondering if was overfilled myself. Did not have a leak until i changed fluid. I have determined it was the seal as it is leaking down on the inside of the disk. I have heard the seal is not too high at the dealer?
Re: drip,drip.....
« Reply #7 on: June 18, 2012, 07:09:27 PM »
Here's an account of my experience with the job:
http://www.motobrick.com/index.php/topic,1880.msg9509.html#msg9509
It's not hard! Take your time, study the pdf how-to linked to in that thread, and ask questions here if you get stumped.
jeffhestand
Re: drip,drip.....
« Reply #8 on: June 19, 2012, 12:38:48 PM »
got seal and o ring today from the bmw dealer for about 40.00. I need to do spline grease anyway so i figured i would go ahead and the the oring and seal while im in there. Here we go!
