Author Topic: Hard Case Hinge Replacement  (Read 16220 times)
Offline TaosBrick
  • RedHotMotoBricker
« on: May 30, 2012, 03:29:56 PM »
Duck asked me to post this awhile ago, so here goes:
Busted Hard Case Hinges? No problem, go to this fiche on Bike Bandit - http://www.bikebandit.com/1992-bmw-k75/o/m82#sch352509
or simply order this part#: 376260
Pry the old busted ones off the small plastic studs that hold them on the case like this,
Then push them off the rest of the way with a drift or big nail and hammer like this.
Slide the new ones on...
Until they click into place.
Done Deal.
- Samurai Maxim
Re: Hard Case Hinge Replacement
« Reply #1 on: May 30, 2012, 03:57:18 PM »
Thanks for posting this.
Th BMW part # for the hinges is 46542300039.  There are  two per side.
FYI: I find that a 1" chisel is a good tool for sliding them off with some light taps from a hammer.
Offline skidmore
« Reply #2 on: May 02, 2013, 03:48:13 PM »
This thread caught my eye. The previous owner of my bags cobbled one back together with a couple hardware store hinges. Little did he (or me) know they are a $5 piece from the Bandit!
BTW, the part number is 376154 if I'm reading the fiche properly.
current: 1992 K75RT ABS and elec windshield, baby!
previous: 1992 K75, 1983 R100, five spooo-ooort bikes, a Sportster, two XS650 Specials....and probably a partridge in a pear tree somewhere along the way
Frankenduck said: "I haven't backfired a K75 in lord knows how many miles - but I could if I wanted to."
« Reply #3 on: June 17, 2016, 01:29:00 PM »
They're $5.50 each at http://www.bobsbmw.com, now $6 each at Bike Bandit.
Just sayin'
Offline kioolt
« Reply #4 on: June 17, 2016, 02:32:53 PM »
My first set of hinges failed while on a trip.  Since then I carry 2 spare hinges with me all the time.
« Reply #5 on: June 17, 2016, 02:56:42 PM »
Replaced mine with hardware store hinges 20 years ago.  Don't need to carry spares.  Face it, some BMW OEM parts are failures waiting to happen.
Offline Mooseman
« Reply #6 on: February 07, 2018, 11:48:20 PM »
What hinges did you use and how did you attach them?
  • N. Cal
  • K75C
All Rides are good, Just some are GREAT!
« Reply #7 on: February 08, 2018, 09:00:40 AM »
I carry a couple spare hinges in one of the pockets in my case liners.  I had to replace one when I dropped my K75RT on a muddy Nebraska road a couple years ago.  Took about 10 minutes on the side of the road to change it.  I like to think that the hinge breaking saved the case when the bike landed on it.
Considering that these $6 hinges probably have nearly 25 or more years on them, and a couple thousand cycles, I can't really complain when one of them fails.
« Reply #8 on: February 08, 2018, 09:40:46 AM »
I think I used 1 1/2" or 2", just drilled holes and bolted them on.  Pop rivets would work too.  Same deal with the pot metal latches.
« Reply #9 on: February 08, 2018, 11:03:14 AM »
+1
  • 1995 K75 89,000 miles
Offline Mooseman
« Reply #10 on: February 08, 2018, 12:50:46 PM »
Thank You.... Well done and with pictures... Awesome  :riding:
  • N. Cal
  • K75C
« Reply #11 on: February 08, 2018, 12:58:18 PM »
That must also explain the sacrificial mirrors and turn signal lenses BMW is so fond of  :clap:
« Reply #12 on: February 08, 2018, 04:39:30 PM »
I've replaced one complete set in twenty years. And mine have always given me warning of the impending disaster by one hinge always starting to split first. I only had to replace one side late last year. And I should carry spares, and I will get around to it eventually. :dunno
Offline TaosBrick
  • RedHotMotoBricker
« Reply #13 on: April 01, 2018, 09:55:04 PM »
Hmm... $4 for a pair of hardware store hinges that will last ages, or $6 a pop for something that'll go south in a year or two of regular use. Guess I'll be heading to Ace soon. I like the pop rivet option.
- Samurai Maxim
Offline kioolt
« Reply #14 on: April 01, 2018, 10:50:32 PM »
I bought my 91 K100LT new in 91 and I have only replaced one set of hinges.  I do carry a spare set in the bags but I have never needed them.  I wouldn't consider them to be a once every year or two by any means.
Offline mavam
« Reply #15 on: November 22, 2019, 12:04:30 AM »
Glad I found this thread. The outer shell on my left case fell off when I opened it on Monday. Thought I’d have to replace the whole thing but no. They’re up to about $8 per hinge now.
  • Virginia
  • 1990 K75RT
« Reply #16 on: November 22, 2019, 12:43:11 AM »
A couple of people have 3D printed tragkorb hinges. One was an OEM copy and one was a modular multi part hinge with a bolt as a pivot. However as per a lot of Brick owners I'll stick with the OEM as they lasted well over 20 years the first set and I now carry a spare pair.
« Reply #17 on: November 22, 2019, 08:35:04 AM »
I bought a set of replacements when I first got my '91 R100RT because I was unimpressed with what I thought were flimsy hinges that would fail at any time.  40k miles later those are still working fine.
A slide into a ditch with my '93 K75 caused the case cover to detach because of the sacrificial hinges saving the case as a whole.  I did have to replace the lock at the bottom but new hinges and lock brought it back to regular use.
