Author Topic: Replace bulbs on K75 standard headlight  (Read 9672 times)
Offline ok75
« on: May 21, 2012, 08:48:15 PM »
Probably super easy, but how do you remove the headlight ring and bucket from a K75 standard headlight to easily replace bulbs?
Thanks in advance!
Re: Replace bulbs on K75 standard headlight
« Reply #1 on: May 21, 2012, 08:57:31 PM »
There's a screw on the bottom. Undo it, and pull from the bottom, then lift off the lens. The bulb is in the back. pull the connector, and there is a spring clip of some sort that holds the bulb. Pop it off, and swap the bulbs, without touching the glass of the bulb. I would clean it with rubbing alcohol or acetone before putting it in.
You should add relays (and a high wattage bulb if desired) while you are in there. Not a big deal to do.
Offline BillyMac
« Reply #2 on: May 21, 2012, 09:05:10 PM »
I'll piggyback on this question. Any recommended better bulbs and relays to add? I've got the old low yellow bulb.
1990 BMW K75 - Current
1967 Yamaha YCS1 Bonanza 180
Offline ok75
« Reply #3 on: May 21, 2012, 09:21:34 PM »
Thanks, wmax!
(I thought that screw was to adjust be beam angle . . . suppose that's done by simply adjusting the whole bucket + headlight in the mount).
Offline Photog
« Reply #4 on: May 22, 2012, 08:34:05 AM »
Quote
The Eastern Beaver relay kit is highly recommended, well made, plug and play if you don't want to clip wires. Full discussion of the topic here;
Headlight/relay discussion; http://www.motobrick.com/index.php/topic,268.0.html
  • NNE
  • K75-S
« Reply #5 on: May 23, 2012, 09:49:11 PM »
Thanks, wmax!
IIRC, there is a screw on the side, that is for adjusting beam angle side to side.
mrvhappy
« Reply #6 on: November 27, 2014, 04:44:51 AM »
Hi there,
Has anyone replaced the standard head & side light bulbs with Canbus LED's?
Regards
Ben
