Author Topic: May have stripped final drive fixed pivit bolt on my K100rs, d'oh!  (Read 9921 times)
Offline tsbt
Removing the paralever tonight I ended up stripping part of the Allen hole, used a mallet to pound the 12mm Allen socket back in to retap the shape. Tried it again a second time with a pipe on the end for leverage and busted my socket extension off inside my Allen socket. The 12mm Allen seems to fit relatively snug still but I don't want it to happen a second time. Should I torch it? just worried about the boot melting if I do because it's so close. Guess I'm buying 12mm Allen Wrench next time and heating the Locktite with a torch, hopefully I can still get it out :imwithstupid: Any suggestions for round two?
Thanks,
c
92 K100RS 4V
75 KE125
Re: May have stripped final drive fixed pivit bolt on my K100rs, d'oh!
« Reply #1 on: May 14, 2012, 09:47:47 PM »
Chinese tools.............?
If you`re concerned about the boot, hold a piece of sheet metal in front of it, while heating the bolt.
(the sheet metal need to have decent bit of area, or you suddenly start to add new words to your vocabulary).
Inge K.
« Reply #2 on: May 14, 2012, 09:59:53 PM »
Just use a small propane torch and put the flame right on that puppy. Doesn't need to glow red. Then find some tool that will fit in that hole you made. If you burn the boot you can just add it to the order. You do need a new bolt. :giggles
Offline tsbt
« Reply #3 on: May 14, 2012, 10:56:00 PM »
Thanks Inge. Thanks Red. Got my torch. Chinese tools? Naw Craftsman, brand new too. Maybe i need a good socket wrench, add that to the list too.  :tongue
92 K100RS 4V
75 KE125
Offline CRASH
« Reply #4 on: May 15, 2012, 01:37:32 AM »
Heat gun works well for that.  Not to expensive and won't burn off your paint.
- CRASH -
Offline tsbt
« Reply #5 on: May 15, 2012, 09:34:44 AM »
Doesn't look like this part has an Allen hole, I'll just assume it does and order it. Don't you just hate $67 mistakes! Yeesh
92 K100RS 4V
75 KE125
Offline Niemand
« Reply #6 on: May 15, 2012, 01:33:13 PM »
Not intending to hijack, but...
Actually brand new Craftsman tools have a very high probability of being from China from what I have been seeing lately.
Niemand
1994 K1100RS
Offline tsbt
« Reply #7 on: May 15, 2012, 04:59:30 PM »
Yes, discovered the same digging around online today. Yikes!
92 K100RS 4V
75 KE125
Offline tsbt
« Reply #8 on: May 16, 2012, 06:53:04 AM »
Just examined the ratchet set package. Stanley. Made in Taiwan.
92 K100RS 4V
75 KE125
thebob
« Reply #9 on: May 16, 2012, 09:51:28 AM »
To heat the locktite I would use a soldering iron. Thats what I do for disk bolts.
Duc750
« Reply #10 on: May 18, 2012, 05:03:27 PM »
My preffered method is a 4 ft breaker bar and a hair dryer! the Flex in the breaker bar seems to work to load up the pivot pin and ease it out. Same principle as a kinetic recovery of a stuck 4*4 (or SUV I guess)
Offline tsbt
« Reply #11 on: May 27, 2012, 08:24:59 PM »
Success, torched the bolt (ordered a new one from Frankenduck) used a 12mm Allen Wrench and a pipe for leverage and voila  :2thumbup: snapped free, didn't strip. Final drive and my swing arm are off and on the floor for my spline lube, the only thing I need now is to get this spline out of the female holding it into the transmission. Something about a c-clip/u-clip but i can't seem to find it. Must be all the crud in there. Should it pop out fairly easily? once I find this u-clip of course.
I'll also post some pics of my splines hopefully they're okay, saw a bit of wear, fingers crossed...
c
92 K100RS 4V
75 KE125
Rick G
« Reply #12 on: May 27, 2012, 09:30:29 PM »
You won't see the circlip it is inside the spline on the drive shaft. Put a large screw driver into the center of the uni and lever against the back lip of the transmission. just a short sharp pull is enough and make sure it clips back into place when you are reassembling. Enter the spline just and give it a sharp push you will feel it clip into place.
The same applies when doing the rear section onto the rear drive.
