Author Topic: Leaky hose coming out of the "box" under the gas tank of my 92 K100RS  (Read 9457 times)
Offline tsbt
Pardon my ignorance for the names but couldn't figure out the part, it's a hose right under the gas tank coming out of a box that leaks and is running down the side of the engine housing. these pictures will describe. It's on the left side buried behind everything. Thoughts? :confused:
92 K100RS 4V
75 KE125
Offline DRxBMW
Pardon my ignorance for the names but couldn't figure out the part, it's a hose right under the gas tank coming out of a box that leaks and is running down the side of the engine housing. these pictures will describe. It's on the left side buried behind everything. Thoughts? :confused: sorry, the pictures rotated counter clockwise 90 degrees here.
Damn your pics are a bit confusing.
Appears to be the FI return hose.
Semi dangerous to run with a cracked hose, read FIRE at 36 psi is NOT a good thing.
Best to replace the injection rail & vacuum hose to the fuel pressure regulator at the same time.
You''ll need FI rated hose and FI rated clamps as the OEM clamps are Otiker single use.
I have a pictorial how to FAQ on hose replacement somewhere. Unable to find it presently. When I get back from cousins wedding tonight, I search more diligently.   Pain in the ass tearing into the airbox the first time around for the return hose R&R.
Gary
Williamsport,Pa
1994 K 75 ABS "custom"
2005 F 650 GS
Offline DRxBMW
Close inspection on my whip makes me now think it's the crankcase re-breather hose now instead of the FI fuel return hose as you have a pic with the TPS included.
Far easier fix _______________.
The hose is leaking oil right ?
Gary
Williamsport,Pa
2005 F 650 GS
It looks to me like it's your block vent line.
part # 11 15 1 461 835
It runs from a stub on the rear of the block and runs to the air box.
Very common for this line to be cracked and leaking oil/vacuum.
This was one of the lines that lead me to replace ALL of the rubber hoses(less the intake stub tubes), lines, o-rings, etc... that I could find or get at on my '95 a couple of years ago.
Plain and simple they were bad from age, not mileage.
Offline tsbt
Thanks Gary big relief. Made quite a mess I got worried there.
Smart move Scott, I noticed a few others that are starting to crack around there also. Might do the same.
92 K100RS 4V
75 KE125
Blaze, this is a for K1100 but might help you get started.
Offline DRxBMW
Funky breather hose mainly affects idle, EASY R&R.
Gary
Williamsport,Pa
2005 F 650 GS
EASY R&R.
Not so much on a 4V K.  Not out in the open like it is on a 2V.
Offline tsbt
Hey Mystic, thanks. Love how each time I find something weird on my K I get a new detailed and highly documented procedure. Nice one much appreciated for the full deal.
At this point my mechanic Chuck is wondering if I'm seeing another woman. :bmwsmile
92 K100RS 4V
75 KE125
