Author Topic: daft question 101  (Read 5733 times)
Duc750
daft question 101
« on: May 12, 2012, 08:44:07 AM »
Ok, I feel like a right muppet asking this but how do I get the bar end weights (or covers I guess) off so I can change the grips?
Cheers
Guys
Offline DRxBMW
Re: daft question 101
« Reply #1 on: May 12, 2012, 10:36:00 AM »
Cheers
Guys
Simply loosen the outside bolts on the weight and wiggle them out, easy beans.
Gary
Williamsport,Pa
1994 K 75 ABS "custom"
2005 F 650 GS
Duc750
« Reply #2 on: May 12, 2012, 11:16:57 AM »
That was exactly my plan before realising I had no outside bolts! Its so easy on my r850 but I just can't see what to do here.
« Reply #3 on: May 12, 2012, 11:19:48 AM »
If they're factory K1100 bar ends then you need to pull the plastic cap(21) off to access the mounting bolt.
Duc750
« Reply #4 on: May 12, 2012, 11:22:57 AM »
Ah ha, that looks like it, I didn't realise those were just caps or they were made out of plastic :). I take it they do just "pull" of and shouldn't need persuading?
« Reply #5 on: May 12, 2012, 11:26:32 AM »
Spin them clockwise while pulling on them. (And be careful not to tip your bike over in the process.)
Duc750
« Reply #6 on: May 12, 2012, 11:38:47 AM »
Wire brush time then I guess
I've heard of electrolytic corrosion but this is pretty horrid under plastic !
