Author Topic: Valve clearance (4V motor) questions  (Read 6168 times)
Offline Bob T
« on: April 19, 2012, 07:59:25 AM »
Checked my valve clearances last night for the first time.  Bike is a '95 K11RS with 33K miles.
I was using standard feeler gauges with metric markings, so I had .127mm, .152mm, .178mm, etc.  You all know what I am talking about...(going to pick up a metric set soon).
Anyway...it appears I have one tight valve on the intake.  .152mm (.006) won't go, .127mm (.005) goes easy....
Question #1: Should I go through the trouble of adjusting the valve clearance to correct this one valve?
Question #2: The valve cover had some silicone sealant between the rubber gasket and head.  Is this normal?  If so will any gasket sealant work, or should I use some specific?
Thanks!
'96 K1100RS
'01 Triumph TT600
'83 Suzuki GS1100E
'95 K1100RS - Totaled
"I always prefer to believe the best of everybody, it saves so much trouble." -- Rudyard Kipling
Re: Valve clearance (4V motor) questions
« Reply #1 on: April 19, 2012, 10:15:50 AM »
Usually, you want the intakes on the tight side of spec, and the exhaust on the loose side. You also want them equal to each other, so much as is possible. I would bump them all to ~.15+ mm.
I would say at the tightest, you want .006 go, .007 no-go.
The valves recede faster with lower miles, and (overly) tight clearances can lead to burnt valves.
What are your other clearances?
Offline Bob T
« Reply #2 on: April 19, 2012, 03:22:41 PM »
I understand the cam followers come in .05mm increments, so I am not sure how you would do that.  If I am at .14mm, I could go to .19mm., etc.
Quote
The other valves are within spec.
But, question number one still remains...should I bother to go through the whole adjustment procedure for one valve that is .01-.015mm on the tight side?  Will my motor self-destruct on our first 1000 mile weekend?  Or can I let it go for now? :dunno
As for question #2, I found the answer with a little searching...   :embarass:
Thanks,
'96 K1100RS
'01 Triumph TT600
'83 Suzuki GS1100E
« Reply #3 on: April 19, 2012, 03:34:35 PM »
You're probably fine for now. I'd check it in a little while. Maybe bump them all to .19 later.
Offline Bob T
Re: Re: Valve clearance (4V motor) questions
« Reply #4 on: April 19, 2012, 04:19:23 PM »
Thanks...I will...
'96 K1100RS
'01 Triumph TT600
'83 Suzuki GS1100E
