Author Topic: fuel pump test?  (Read 4981 times)
Offline craig
fuel pump test?
« on: April 17, 2012, 06:41:09 PM »
I've removed the fuel pump from my K75 and removed most all of the primordial goo which was the rubber vibration damper.  The pump, when connected to voltage makes a buzzing sound, but does not pump and produces no torque.  Is this pump salvageable?
Thanks!
Rick G
Re: fuel pump test?
« Reply #1 on: April 17, 2012, 07:32:34 PM »
You can get them apart but its hit and miss if it goes back together properly. Probably best to get a new one but no need to buy OEM http://www.motobrick.com/index.php/topic,2058.0.html
Offline DRxBMW
Re: fuel pump test?
« Reply #2 on: April 17, 2012, 09:53:39 PM »
Thanks!
NO ______________ !!!
Gary
Williamsport,Pa
1994 K 75 ABS "custom"
2005 F 650 GS
Re: fuel pump test?
« Reply #3 on: April 18, 2012, 01:33:52 AM »
Are you SURE it's not working?  Usually if it whir that means it's working.  Stick the base in a small jar of gas and power it up. (Smaller diameter terminal is positive.)  Probably a good idea to hook a hose up to the output on the top and have that pointed somewhere safe. (Not your eyes.)
Offline craig
Re: fuel pump test?
« Reply #4 on: April 18, 2012, 10:17:25 AM »
hmmmm....a little concerned about sparking..is there a problem trying this with water?
Re: fuel pump test?
« Reply #5 on: April 18, 2012, 12:58:36 PM »
Though flammable gas is not nearly as explosive most people assume it is.  (Thank you. TV.)
Just do it outside in a well-ventilated area and you should be fine.
I suppose you could use water though.
