Author Topic: Prodedure for Throttle body Sync  (Read 5632 times)
Skeezer
« on: April 15, 2012, 08:41:46 PM »
Before I get the I told you so's( about touching the little screws with the Blue marks on them)  Yes I did touch them and as the thread says "you'll be in for a world of Hurt"
 So now that I've touch them .What is the procedure for setting them. I have a Carb Tuning tool but I only see 3 Screw, (4 if you count the Throttle Stop Screw)
and I have tried adjusting them but I can't get the desired result.
Help Anyone
Re: Prodedure for Throttle body Sync
« Reply #1 on: April 15, 2012, 09:00:31 PM »
Look here and open the file Scott provided.
« Reply #2 on: April 15, 2012, 09:03:08 PM »
Use the throttle for maintaining your engine speed, not the choke, as the choke doesn't connect at the same spot as the throttle. That and when you are riding you use the throttle anyway, not the choke.
DAMHIK. BTDT.
You want to use cyl #3 as your fixed reference as the throttle cable is connected to it direct and not adjustable.
From there you can set 3 to 4, then 3 to 2 and then 2 to 1. That's if you are using a TwinMax.
If you have a 4 port Carbtune, still use #3 as your fixed reference. Then set the remaining ones the same. 3 to 4, 3 to 2 then 2 to 1.
If you make too much of an adjustment to #4 make sure to check your TPS setting when you are finished.
And to your question, yes there are only 3 screws.
1995 K1100LT 0302044
1997 K1100LT 0302488 (R.I.P.)
