Author Topic: 1992 K75rt - 140/80 instead of 130/90?  (Read 12462 times)
georgethegoat
« on: April 12, 2012, 03:40:12 PM »
new to the forum,
so far best i've found out there.
i've read a few places that people are using 140/80-17 in the rear and 110/80-18 in the front on the k75 instead of the stock recommendation.
why? does it matter whether the bike is RT or not for this switch?
also i'm coming of of a pair of lazertecs and thinking about switching to BT45s. any $.02 on this are appreciated in advance.
Re: 1992 K75rt - 140/80 instead of 130/90?
« Reply #1 on: April 12, 2012, 05:04:40 PM »
One reason to do it is to run radials instead of bias ply tires.   You can get a Michelin Pilot Road 2 or Bridgestone 023 for the front and an Avon Azaro rear.
I'm about to switch my K75 to a Bridgestone BT023 front and Avon Azaro rear next month. (From Michelin Mac 50s.)
georgethegoat
« Reply #2 on: April 12, 2012, 10:00:35 PM »
awesome, thanks for the quick response.
is this tire pairing any better or worse for long trips? i'm doing coast to coast this summer maybe more.
thanks again your wisdom is invaluable.
« Reply #3 on: April 12, 2012, 11:06:42 PM »
What is this "tire pairing" of which you speak?
Quote
I have several ex-girlfriends who would disagree with you. :nono  (I used to be a lot more Type A when I was younger.)
Offline conybeare
  • Conybrick
« Reply #4 on: April 13, 2012, 01:43:14 AM »
Does this switch to wider/lower profile tires require the newer style 3-spoke wheels? It looks like the 3-spokes are a bit wider than the older style wheels, as least in the rear... Front wheel looks to be the same width. I have the older style and I'm interested in making this switch/upgrade.
  • Saint Paul MN
Nothing :o
Previous: 2004 R1100S, 2009 Yamaha FZ6,1990 K75S, 1986 K75C, 1984 Honda VT500 Ascot, 1981 Suzuki GS250T
« Reply #5 on: April 13, 2012, 07:59:02 AM »
Yes, you'll probably want to get the 3x17 rear 3-spoke that came on the later K100s and the K1100LT.
Offline conybeare
  • Conybrick
« Reply #6 on: April 13, 2012, 01:44:21 PM »
Paul Glaves says that using a 110/80 on the front would "slow down" the steering on the front a bit (http://www.bmwmoa.org/forum/showthread.php?t=9824) - has anyone noticed that? Just curious...
  • Saint Paul MN
Nothing :o
« Reply #7 on: April 13, 2012, 01:57:57 PM »
I'm running that combo now on my K75(Mich Mac 50 bias plies soon to be replaced by a BT023 and Azaro radials) and it rides just fine.
I'd guess Glaves' theory is that a tire with a lower aspect ratio will have a slightly larger contact patch and therefore take a smidgen more force to turn but  I doubt you'd even notice it. .I don't.
The wheels on my K75 are from a K1100LT:
Front: 2.5 x 18 running a 110/80-18
Rear: 3 x 17 running a 140/80-17
Offline CRASH
« Reply #8 on: April 13, 2012, 02:40:57 PM »
Concur, "theory" being the operative word here.  Yes, physics says it will slow down your steering, now much and how noticeable depends on a lot of variables.  Since the Duck has actually done it and is not therorizing, I would tend top believe it would present minimal risk.
I have played with tire widths my entire life ... the only reason I could see even bothering to change to something non-specified is to take advantage of new technology (eg. Radials) or to deal with tire sizes that have been obsoleted.  If you don't go crazy on over sizing, handling is really not much of an issue for most.
- CRASH -
Offline lukeman
« Reply #9 on: April 13, 2012, 02:41:53 PM »
I run the 140/80V-17 on the older wheels without any problem as do other people.
« Reply #10 on: April 13, 2012, 07:28:50 PM »
Just a word of warning to remember, be careful of a taller tire up front on a stock rim so you don't rip it up with the fork tree cover screw. (for those of you that have it)
1995 K1100LT 0302044
1997 K1100LT 0302488 (R.I.P.)
Offline Roy S.
« Reply #11 on: April 15, 2012, 10:57:02 AM »
Looks like a good combo. Clearances look a little tight for a 3 x 17 wheel and tire (http://www.sporttour.com/shopexd.asp?id=1102 ) for the rear of an K75RT. Do you suggest any modifications? Such as shims to the wheel for frame clearances, or grinding off some of the center stand?
K75s (will be selling)
K75RT (BabyBlue)
K1100lt (on going project)
"I prefer dangerous freedom over peaceful slavery" TJ
