Author Topic: 85 K100RT Spline Lube  (Read 4404 times)
jeffhestand
« on: April 04, 2012, 03:47:11 PM »
Hey everyone- i trust that my fuel pump fix is going to work but.... before i get her licensed or even ride very far i want to do the spline lube. What is the best tutorial for doing this with no manual yet. Also- i used to be a Schaeffers lubricants rep and have a great moly grease for medium speed operations. Do you think it will work? What is the RPM this is turning ?
Re: 85 K100RT Spline Lube
« Reply #1 on: April 04, 2012, 04:15:40 PM »
I have no idea how fast it turns but you could figure it out:
Find an online tire calculator to calculate the circumference of the tire.
The final drive gear ratio is probably 31/11. (It's stamped on the FD near where it bolts to the swing arm.
The 1-5 gear ratios are 4.50 / 2.96 / 2.30 / 1.88 / 1.61:1
At 60mph the engine is turning at x,xxx RPM.
Just do this backwards:
I recently did a write-up on an ABS II K1100RS spline lube.  Sometime in the next few days I'll do a K75/K100 version of it since most of it is very similar.
