Author Topic: 1993 K75S - OEM Rear Shock Measurement  (Read 12929 times)
Offline GasStation
  • 93 K75S Mystic Red
« on: March 25, 2012, 12:08:21 AM »
Do you have an OEM rear shock on your K75S?
What does your rear shock measure from eye bolt to eye bolt?
My OEM rear shock measures 349-350mm.
I just purchased a Wilbers 630 and it measures 344mm which is a little less than 1/4" shorter. Wilbers states that 344mm is the manufacturer's standard rear shock measurement for a K75S.
Here are two pics, one is of the OEM shock removed, while the other is the brand new out-of-the-box Wilbers 630 wonder from Germany:
93 K75S Mystic Red
IBA #9469
Re: 1993 K75S - OEM Rear Shock Measurement
« Reply #1 on: March 25, 2012, 01:05:15 AM »
greetings gasstation...
welcome to motobrick.com...
i dont know... butts a 1/4 inch aints much and when properly dialed in it will be 100% yeeeeehaaaa... im thinking i would set the sag on that wilbers then slowly get it dialed in and not give that 1/4 inch a second thought...
nice brake lines... are those spiegler...
Offline DRxBMW
« Reply #2 on: March 25, 2012, 11:28:14 AM »
New Wilber 641 on the GS was slightly longer than OEM stock Showa, ____ NO issues.
You will LOVE the Wilber !  GREAT pogo stick, BIG difference in overall handling.
Gary
Williamsport,Pa
1994 K 75 ABS "custom"
2005 F 650 GS
Offline GasStation
« Reply #3 on: March 25, 2012, 09:40:23 PM »
Hello and thanks for the warm welcome.
Yes sir, those are brand new Spiegler brake lines. I have them front and rear. I figured the 20-year old OEM brake lines had accomplished their job and so I elected to change them "on spec". There was nothing wrong with them, no leaks, fissures, or even cracks. I got a special order (no extra charge) for the front brake hose as I changed my S-bars to C-bars and needed a longer length than on the S-bars. Very accommodating those folks at Spiegler despite the mix-up in hose length for the hose connected to the right front brake calliper.
I don't know much about shocks but am willing to learn. I had a choice between the OEM, Progressive, Ohlins and Wilbers. So, the top adjusts what? And the bottom adjusts what?
Gas
93 K75S Mystic Red
IBA #9469
« Reply #4 on: March 25, 2012, 10:33:04 PM »
Spiegler doesn't wrap them in a plastic tube?  I thought that was a requirement for them to be DOT street legal.
Not that I care.  Just curious. I have the exact same setup on the rear of my K75. (Galfer stuff in the front.)
« Reply #5 on: March 25, 2012, 11:42:20 PM »
My speiglers came with a coating on them. I got them with the smoked coating.
« Reply #6 on: March 26, 2012, 08:45:51 AM »
Gas
here is a thread on how to adjust rear shocks:  http://www.motobrick.com/index.php/topic,1460.msg6911.html#msg6911
Offline GasStation
« Reply #7 on: March 26, 2012, 05:04:49 PM »
Thanks WayneDW for the link, I will read and bone up on the theory of shocks.
Frankenduck, the lines are coated with a rubber or nylon coating. Mine is transparent as I was too cheap to pay the extra $20USD for the coloured version.
BTW, I browsed through your thread on the rebuild of a K75 - truly amazing! I am impressed, well done!
93 K75S Mystic Red
IBA #9469
