Author Topic: Curing a sticky/slow throttle return on a K75 or 2V K100  (Read 13016 times)
« on: February 14, 2012, 05:37:29 PM »
The throttles on the 2V K bikes don't tend to "snap back" like they do on many motorcycles.  After trying different approaches to "cure" this I finally found a solution to this minor inconvenience.
The first thing to do is to make sure that your grip rubber isn't rubbing against the side of the throttle perch.
The next thing is to clean all of the old grease out of the throttle gears next to the master cylinder:
a) Remove the Phillips screw near the bottom of the right combination switch to remove the switch from the throttle perch.  Be sure to use a good screwdriver with appropriate pressure as that screw can be sticky and it's easy to strip the head if you're not careful.
b) Remove the large black Phillips screw (7) to the right of the master cylinder reservoir.  Once that screw has been removed the plate (8) that it holds down can be removed.  This will expose the throttle gears and allow the throttle tube to be pulled back.
c) Clean out all of the old grease in the throttle gears and on the throttle tube gears.
d) BMW recommends that these be regreased with fresh grease but what I've found works well is spraying the cleaned up gears with a bunch of 3M spray silicone lubricant. It's a much lighter and thinner lubricant which doesn't impede the movement of the throttle as much as a thicker grease does.
e) Also spray down the handlebar under the throttle tube with the silicone lubricant.
When you put everything back together you'll find that the throttle will "snap back" much better than it ever has.
Offline DRxBMW
Re: Curing a sticky/slow throttle return on a K75 or 2V K100
« Reply #1 on: February 14, 2012, 06:32:12 PM »
here's a PDF on throttle service.
Going with the silicone spray is certainly different.
Gary
Williamsport,Pa
1994 K 75 ABS "custom"
2005 F 650 GS
« Reply #2 on: February 14, 2012, 08:42:50 PM »
DRx:  Yeah, the point of my post was that if you use a lubricant that's thinner than lithium grease (like the 3M silicone spray) that it doesn't gum the gears up like even fresh lithium or heavier greases will do.
You should try it.... :2thumbup:
Offline DRxBMW
« Reply #3 on: February 14, 2012, 09:17:13 PM »
:hmm: wonder how a Teflon spray would work instead ?
Clean, slippery, chain and cam live in semi protected area, worth a shot.  On the MTB TriFlo is wunderbar lubricant.
Couple of add ons for the throttle service.
* top plate screw can be a real bitch to remove. Use a hand impact driver if so. NOT the impact part just the driver. There's enough weight to the tool to break it free "easily" compared to a conventional screwdriver.  Akin to brake reservoir screws,there's a slight corrosion factor present from being out in the weather.  However the top plate screw actually needs to semi tight. (see below)
* the top plate needs to be all the way down and fastened securely upon reassembly. DAMHIFK  If it loosens, the teeth do NOT engage properly giving you only half throttle.
Gary
Williamsport,Pa
2005 F 650 GS
