Author Topic: Fuel Tank Info  (Read 6609 times)
Offline argent brick
Fuel Tank Info
« on: February 06, 2012, 08:33:13 PM »
Can anyone tell me what year and model K75 fuel tanks will fit each other ?
Lynn
1995 K75/3A Standard
1978 Yamaha xs750(P.O.S.)
1976 R60/6 RIP
Re: Fuel Tank Info
« Reply #1 on: February 06, 2012, 09:04:23 PM »
To start with, any K75RT tank is out as they use K100 tanks.
I don't know the exact details but according to the parts catalog something changed in production month 1/93 so if you're looking for a tank for a 95 then you'll want to get a model year 93-95 tank from a K75 or K75S. (K75Cs were out of production by then.)
Offline Uffda
Re: Fuel Tank Info
« Reply #2 on: February 06, 2012, 09:27:36 PM »
Jumping in with a fuel tank related question:  What's the difference between a Bridge-Mounted tank and a Plug-Mounted tank?  Most specifically, which version would a 95 K75RT have?  The repair manual gives a different torque sequence for the frame bolts, depending upon the style of tank.
  • New England
  • 1995 K75RT
Robert
Re: Fuel Tank Info
« Reply #3 on: February 07, 2012, 09:15:46 AM »
Bridge Mount fuel tank:  http://www.maxbmwmotorcycles.com/fiche/Diagrams/B0000419.png
Separate metal stamping (9) that "bridges" the frame rails and secures the tank using a single screw (8) through a tang on the tank.
Plug Mount fuel tank:  http://www.maxbmwmotorcycles.com/fiche/Diagrams/B0000421.png
Welded brackets on the frame accept 2 plugs, integrated with the tank and located on either side.  A rubber ring (14) in each bracket acts as vibration damper and "C" clips (15) firmly secure the tank to the frame.
Only early model K-bikes used the bridge mount. A '95 K75RT would use the plug mounts.
Offline Uffda
Re: Fuel Tank Info
« Reply #4 on: February 07, 2012, 08:08:51 PM »
 :2thumbup: Thanks Robert!
  • New England
  • 1995 K75RT
Robert
