Author Topic: LED turn signals  (Read 11333 times)
Offline DRxBMW
LED turn signals
« on: January 17, 2012, 08:23:24 PM »
Drake,
Do you have LED turn signals installed in any of your K's yet ?
I have a guy who has an interest in rewiring his.
Any tips or tricks if so ?
THANX __________________________________.
Gary
Williamsport,Pa
1994 K 75 ABS "custom"
2005 F 650 GS
Re: LED turn signals
« Reply #1 on: January 17, 2012, 08:52:00 PM »
The only thing non-LED on any of my Ks is the headlight.
One solution: DIY LED flasher relay
Offline DRxBMW
« Reply #2 on: January 18, 2012, 08:07:08 AM »
I did manage to source some plug & play flashers this AM. The deluxe model below is even programmable. Ideally, I would like to whip a kit, as this brickhead resides in NYC rather than ride to my house for a install.
http://www.customled.com/products/flasher_relay/flasher_relay.htm
deluxe model  $49.00
standard model $19.00
http://www.ledshoponline.com/electronic_flasher_cans.htm
flasher can $20.00
Gary
Williamsport,Pa
2005 F 650 GS
« Reply #3 on: January 18, 2012, 08:26:59 AM »
One issue that needs to be addressed is that K bike turn signals use momentary switches while most other turn signals (other bikes, cars, etc...) use non-momentary switches so that's what most flasher relays are designed for.  I addressed that by using latching relays in the circuit that I put together,
Offline DRxBMW
« Reply #4 on: January 21, 2012, 10:08:38 AM »
Thanks for all the suggestions, a plug & play kit is now worked up and in the mail for my motobricker buddy in NYC.
Last winter, I did your front reflector LED project on his whip. I must admit it does have a different look now.
My next mod, at least on the GS is, LED turn signal/running light mirrors. Have you ever entertained the idea of working up a sequential turn signal flash rate ?
Home made mirror LED vid:
Snowing like a bandit currently. As soon as it quits, I'm breaking out the skis.
Gary
Williamsport,Pa
2005 F 650 GS
« Reply #5 on: January 21, 2012, 10:37:19 AM »
hey doc... whats in the freezer...
Offline DRxBMW
« Reply #6 on: January 21, 2012, 12:48:59 PM »
BEEF
Gary
Williamsport,Pa
2005 F 650 GS
« Reply #7 on: January 21, 2012, 12:50:31 PM »
i was figuring lebanon bologna...
