Author Topic: FS: Paralever rear end with custom gear set  (Read 5360 times)
Offline dave n
« on: January 16, 2012, 12:33:02 PM »
Approximately 10,400 miles ago I had the 2:54 gear set
from a R1200CL installed in my K1100 housing. Work done by Anton
Largiader @ http://largiader.com/shop/. All seals and bearings except
the large crown bearing were replaced.
Not cheap to do - but not a job for the back yard mechanic either. Gear lash
and preload have to be set right the first time or you get to buy more
expensive BMW parts. Takes a little more clutch slip starting out - especially
two up - other wise the engine has plenty of torque for the new gears.
At 70 mph - 4000 rpm on tach - not sure how accurate speedo is. About
20-25 more miles on a tank of gas .??
Will include two good used final drive pivot bearings.
Also the rear wheel will now have 4 bolts (like the K1200RS/LT; Oilheads) instead of 5.
I'll send a pic if you want one - still looks the same as before.
$450.00 shipped to your door in USA only!
e-mail best
Fits K1, K100RS (1991-1992), K1100LT and K1100RS (1993 - on) Paralever rear suspension
  • Gastonia NC
  • 1993 K1100LT w/Hannigan sidecar 1999 Cagiva Gran Canyon
Dave Norris
