Does this engine sound normal to you?
Topic: Does this engine sound normal to you? (Read 1925 times)
3dachshunds
Motobrick Curious
May 20, 2026, 08:13:42 PM »
I’ve been working on 1992 k100rs since last fall and finally got the bike running (clogged injectors). I was super excited that I finally got it running, but didn’t actually ride until now. (New fluids, new tank innards, new spark plugs). I don’t like how it sounds at idle. It sounds to me either misfire or a problem with crankshaft bearings. It has hesitation at about 4.5-5k RPM, around 80MPH. It starts feeling sluggish. Please let me know what do you think.
https://drive.google.com/file/d/1Qqn2XgcRyBtIj7QKubrpFsX3cLhWUb_L/view?usp=drivesdk
USA
1992 BMW K75, 2013 Triumph Tiger 800 roadie
Filmcamera
Re: Does this engine sound normal to you?
Reply #1 on:
May 21, 2026, 03:44:30 PM »
That does not sound right to me! That intermittent thunk is not something my 1991 K1000 RS does. I sounds like you might be in three cylinders. If you have a gun type thermometer try measuring the heat of the four exhausts as they come out of the engine. If one is much cooler it might not be firing right.
San Jose, Costa Rica
1991 K100RS 16v ABS1, 2022 Triumph Tiger 900 Rally Pro
Poserbricker
Laitch
Faster than a speeding pullet
Administrator
Reply #2 on:
May 21, 2026, 10:15:43 PM »
Among several causes, defective fuel injectors and faulty coils or coil connections can cause knocking. Were all the injectors replaced, or were they professionally cleaned?
Along the Ridley in Vermont.
1995 K75 102,000 miles
3dachshunds
Motobrick Curious
Reply #3 on:
May 22, 2026, 12:01:41 AM »
I cleaned injectors by energizing them directly from battery and spraying brake cleaner simultaneously. Probably damaged one or more during the process. I hope that’s the root cause. New injector set should arrive next week from Euromoto.
USA
k100
idle
hesitation
