Author Topic: Exhaust leak barn find  (Read 3861 times)
Offline Atabeach
« on: April 09, 2026, 02:16:16 PM »
Any tricks to solve an exhaust leak. See photo #1. Soot would lead me to believe exhaust gasses are getting by. This is the second time taking exhaust off , I snugged her up real good last time. TIA. Backfires moderately…otherwise runs good. OK MY BAD…DISCOVERED COPPER GASKETS! on order now…sorry guys.
  • Ponte Vedra Fl
  • 1994 k75 Standard, 1985 k100 ( BFK 49 states) 2002 Harley’s Dyna, NEW 1999 R1100SA & my favorite 2006 Vespa LX150!
Re: Exhaust leak barn find
« Reply #1 on: April 09, 2026, 03:42:45 PM »
Consider that the fuel mixture in that cylinder might be running rich or not being fully combusted. Look for oxidation and looseness on the coil and plug wire terminals. Run the engine then remove the plug for that cylinder; check the spark plug gap. If you don't find anything wrong with those, check the valve clearances for that cylinder.
Offline Atabeach
« Reply #2 on: April 09, 2026, 06:37:00 PM »
On it Laitch! I’m ordering copper gaskets just in case but will check coil & plugs…she really purrs nicely. Plus there is really no buildup on the tailpipe…thanks again
  • Ponte Vedra Fl
Offline Duckbubbles
« Reply #3 on: April 10, 2026, 10:15:53 AM »
Make sure you remove all the old gaskets.  I do all my own maintenance and I was horrified to find I had left TWO gaskets piled up in there.  Only discovered by having trouble refitting the exhaust.  To this day I can't figure out how I did that.  Used a dental pick to fish them out.
Frank
  • Austin, Texas USA
  • 1985 K100/1100RS
'23 R1250RS
'03 R1100S BCR #6/200
500,000+ BMW miles
