New Clutch boot leak!
Topic: New Clutch boot leak! (Read 4007 times)
Atabeach
^ Proficient Motobricker
March 30, 2026, 06:08:43 PM »
Hey guys, working on a barn find 85 k 100. Covered the basics including spline lube… new clutch boot, never saw one leak from new. Clutch arm seems square and lined up nicely. Clamp not over tightened. Leaking from top, where metal meets boot. TIA
Ponte Vedra Fl
1994 k75 Standard, 1985 k100 ( BFK 49 states) 2002 Harley’s Dyna, NEW 1999 R1100SA & my favorite 2006 Vespa LX150!
Laitch
Faster than a speeding pullet
Administrator
Re: New Clutch boot leak!
Reply #1 on:
March 30, 2026, 06:48:29 PM »
Along the Ridley in Vermont.
1995 K75 102,000 miles
Agree x 1
View List
Atabeach
Reply #2 on:
March 30, 2026, 06:49:56 PM »
Working on it now Laitch. Thanks! Ok sooooo….Throw out Chris Harris how to adjust cable video 😜😜 Seems the aftermarket cable had to be adjusted FIRST to get some tension on clutch arm. ( 3” from ferrule to top of barrel) ….THEN adjusted bolt, making sure there was no tension on clutch rod. Play at lever is 2mm…good to go! Thanks again Laitch!
Ponte Vedra Fl
