Author Topic: No power to fuel tank 4 pin connector  (Read 7785 times)
Offline 3dachshunds
« on: December 29, 2025, 11:02:19 AM »
Good morning everyone, I am trying to start new to me 1992 k100rs that has been sitting with half tank of gas for two decades! Well, after cleaning the inside of the tank as much as I could and replacing fuel pump, filter and lines, installed new battery, it does crank strong but the fuel pump is not running. So this is what I found so far: There is no load on 4 pin connector when cranking (measuring voltage across brown and green/white leads). All fuses are intact. Fuel pump relay appears working (solenoid clicks when applied load on terminals 85 and 86). The pump works when powered directly from the battery. So I am not sure how to proceed further. Any help appreciated!
  • USA
  • 1992 BMW K75, 2013 Triumph Tiger 800 roadie
Re: No power to fuel tank 4 pin connector
« Reply #1 on: December 29, 2025, 01:52:20 PM »
When the key is turned to On, can the fuel pump be heard powering up for a second or two?
Offline 3dachshunds
« Reply #2 on: December 29, 2025, 02:04:48 PM »
No, definitely not doing anything.
  • USA
« Reply #3 on: December 29, 2025, 03:03:27 PM »
Is the Brick on its center stand or is it on its side stand?
Offline 3dachshunds
« Reply #4 on: December 29, 2025, 03:11:10 PM »
On the center stand
  • USA
Offline Edward
« Reply #5 on: December 29, 2025, 06:48:43 PM »
For good measure, clean all your grounds before advancing. Also, it's worth sending out your injectors for cleaning. New iridium plugs would be a smart choice at this point. Clean your pump connector; it's often a problem area simply due to removing the tank for general maintenance over the years. Age brings on corrosion, which is the foundational mindset.
  • USA
  • K75s 1987 Original owner
Offline Harrowbmw
« Reply #6 on: March 30, 2026, 08:46:44 PM »
Hi Sausage dog lover.
If you're still having difficulties, swap out your EFI 5 pin relay in your relay box.  Just a thought.
Cheers.
  • Brighton, South Australia
  • 1983 K100 1999 K1200LT
