Author Topic: Handlebar mount  (Read 4220 times)
Offline Atabeach
Handlebar mount
« on: November 22, 2025, 09:23:41 PM »
So I am adding longer bars to my 85 standard. The bars have a different mounting system than my other bike, a 1990 S. The bars are not secure at all , moving about 1” when applying pressure forward as if braking. On the 1990 the bottom handlebar bracket is one piece…part of the steering head mount. # 2. Photo the 1985 is bolted on? Photo 1 and exploded view ) It may have not mattered with lower bars as all hand pressure was down while braking, not forward….Im having trouble believing this system is in place for LT models.
  • Ponte Vedra Fl
  • 1994 k75 Standard, 1985 k100 ( BFK 49 states) 2002 Harley’s Dyna, NEW 1999 R1100SA & my favorite 2006 Vespa LX150!
Re: Handlebar mount
« Reply #1 on: November 22, 2025, 11:01:20 PM »
Look here.
Offline Atabeach
Re: Handlebar mount
« Reply #2 on: November 23, 2025, 07:46:11 PM »
Thanks Laitch! The bars move quite a bit…hopefully this tightens them up.
  • Ponte Vedra Fl
Offline Atabeach
Re: Handlebar mount
« Reply #3 on: December 08, 2025, 03:58:57 PM »
Ok sooo the brass washer thing did not tighten the bars up significantly...Also in the process I stripped one of the mounting bars. My next question before buying on flea bay ( $50 )...Are they all the same? that is , do later bikes have a more substantial threaded rod attached to handlebar mount? The threads on mine are 8mm x 125. TIA
  • Ponte Vedra Fl
