Author Topic: How do you remove the nasty gooey residue from tank?  (Read 4043 times)
Offline 3dachshunds
« on: November 21, 2025, 07:25:02 PM »
I am working on new to me 1992 K100RS. The bike set for at least a decade with old gas in tank. I emptied the tank and hoping to remove as much crud as I can. Has anyone cleaned the tank from
rubbery residue? Should I wait until inside is bone dry and scrub with plastic spatula, or should I try to dissolve it? It seems acetone dissolves this stuff well.
  • USA
  • 1992 BMW K75, 2013 Triumph Tiger 800 roadie
Offline Atabeach
Re: How do you remove the nasty gooey residue from tank?
« Reply #1 on: November 22, 2025, 04:28:52 AM »
I recently acquired a 1985 barn find ( see post ) that had been sitting for…a decade or two. Removed innards and used White vinegar overnight….the next day.... hand in tank... scrub with a scotch brite! Two applications. PS try not to get vinegar on paint.
  • Ponte Vedra Fl
  • 1994 k75 Standard, 1985 k100 ( BFK 49 states) 2002 Harley’s Dyna, NEW 1999 R1100SA & my favorite 2006 Vespa LX150!
Offline Kaos
  • Vlad the Extractor
« Reply #2 on: December 08, 2025, 05:25:16 PM »
Atabeach is correct, vinegar, cleaner, calcium remover and fresh gasoline could work as well.
Dont mix them, and after soaking and brushing, rinse thoroughly with water.
Do keep in mind that the tank is aluminium and a high acidity (if i recall correctly above 10%, do check this on beforehand) will bite into the aluminium.
Also i used a dishwash brush with a round head, works like a charm. Not when using gasoline tho.
  • Basically Everywhere
