Author Topic: Shifting out neutral, dies within 2 seconds.  (Read 4684 times)
Offline schrocketeer
« on: October 15, 2025, 06:17:13 PM »
1985 BMW K100 starts okay, revs up okay. When I put it in either 1st or 2nd gear (i.e. not Neutral), not immediately, but less than 2 seconds it does. What could cause this?
This Brick was a "not running when parked" that I've brought back to life this Fall.
The clutch cut-off switch is dis-engaged. I have not checked the Sidestand switch, but am pretty sure I tried kickstand down/ up, and got the same responses.
  (yes, I understand, need to have the kickstand up to go. :-p)
  • North Alabama
  • 1985 K100RT very original
Ken
Re: Shifting out neutral, dies within 2 seconds.
« Reply #1 on: October 15, 2025, 06:34:06 PM »
There's no OEM starter switch connected to the sidestand of a 2V Brick like the '85, so put that in the WIN column. icon_cheers
« Reply #2 on: October 15, 2025, 06:38:31 PM »
Can the rear wheel be rotated by hand when the transmission is in neutral?
Offline Ingo
« Reply #3 on: October 19, 2025, 10:53:45 PM »
Is it possible that the clutch might be dragging?
  • Janesville,  WI
  • 1992 K1100LT
