Author Topic: 1985 K100, tip of key broke off - inside ignition switch  (Read 4988 times)
Offline schrocketeer
« on: October 03, 2025, 08:48:23 AM »
Resurrecting a '85 K100, must have ham-fisted getting the key in to the ignition switch, and broke off 1mm of the tip, inside.
Is there a clever way to retrieve it, and still use the key?
Kpartsholland has a new one for $237
A previous owner moved the ignition switch off the dashbboard to a custom panel hanging off the coil cover (see attached photo). So it's possible I could buy a generic switch, and splice in.
  • North Alabama
  • 1985 K100RT very original
Ken
Current: 85 K100RT, 09 DL650, 16 4RT260, 97 XR100, 70 CT70, 06 YFM400
Past Bikes: 86 K100RT, 85 K100RS, 07 SV1000S, 80 KL250, 99 GS1100, 85 K100RT, 86 VFR700, 91 XR250, 95 VLX600, 86 TRX250, 02 GZ250, 83 Z50R, 78 ATC90, 86 XR250, 79 XR500, 72 AT1, 75 YZ360, 78 DT400, 75 DT125, 73 Trail 70
Re: 1985 K100, tip of key broke off - inside ignition switch
« Reply #1 on: October 04, 2025, 10:59:11 AM »
You could replace it with a simple on/off ignition switch and a couple of relays.
https://www.aliexpress.us/i/3256807133793407.html
« Reply #2 on: October 04, 2025, 05:01:46 PM »
A typical OEM BMW key is steel. A fun procedure might be to get a can of FreezeOff and using its narrow plastic nozzle, bathe the broken bit with spray to shrink it, then try to remove it with a pick and magnet; otherwise, make plans for Frankenduck's suggested modification.
« Reply #3 on: October 15, 2025, 06:21:03 PM »
Tried the Freeze-Off, no luck.
Thanks for Relay suggestion Frankenduck.
Went with a $15 eBay key, 3 position, 3 wire. Previous owner had made a mounting bracket off of the Coil cover, which I utilized (see photo).
  • North Alabama
Ken
