Author Topic: Steering bearing removal - bump on the stem  (Read 3916 times)
Offline 3dachshunds
« on: September 30, 2025, 03:22:08 PM »
I am working on 1985 K100 which seems never spent a single day in a garage and possibly has not seen any service whatsoever… I took apart the bike and was going to replace headstock bearings today, which were completely seized. I finally dislodged remains of bottom bearing, but there is what appears a bump or bent lip on the stem, which prevents it from sliding off. Is this something done on purpose during assembly,
? Is it OK to grind it off to remove the bearing? In a separate question, when installing new races, do I need to heat head tube, or freeze race to facilitate installation? Or just whacking with mallet will suffice? Thank you.
  • USA
  • 1992 BMW K75, 2013 Triumph Tiger 800 roadie
Offline Ingo
Re: Steering bearing removal - bump on the stem
« Reply #1 on: September 30, 2025, 04:59:00 PM »
That slot is for the steering lock. Fine to grind off the bump. Put the stem in the freezer, heat up p the race, it'll slip right into place.
 Be fast with that.
  • Janesville,  WI
  • 1992 K1100LT
Offline bocutter Ed
« Reply #2 on: October 01, 2025, 06:59:05 AM »
Ingo has it. What you were thinking will only make it tighter.
  • Toronto, Canada
