Author Topic: 1996 BMW K1100LT Weird Knocking sound  (Read 2065 times)
Offline cancira
« on: August 15, 2025, 03:05:11 PM »
A new sound has emerged from my bike, a knocking one. It seems as if it was coming from the starter or alternator, the gas tank is also making a loud noise. I am attaching a video for you all to hear. Any advice is well appreciated. Apparently the starter is also leaking oil.
https://jumpshare.com/s/l6LuJaCbYq1i8JNwRg7w
  • Houston
  • 1996 BMW K1100LT
Re: 1996 BMW K1100LT Weird Knocking sound
« Reply #1 on: August 16, 2025, 12:54:52 AM »
If both these sounds started at the same time, they might be related, and over fuelling is a possibility that comes to mind, which just might result in your brick running on only three cylinders, that can cause a knock.
Removing the return hose from the tank and directing it temporarily into a bucket, just might improve the problem, tending to confirm this guess. Directing a spark plug lead to a spare, earthed, spark plug, should result in a drop in revs. If it doesn't result in a rev drop for one of the cylinders, that's a problem.
