Author Topic: Removing gas tank k75s  (Read 3766 times)
Offline Kchop
« on: August 04, 2025, 12:55:44 PM »
Hey group,
Can someone post a link to gas tank removal for 93 K75s .
  • USA
  • 1993 K75s
Offline Smudgemo
  • Intermodal Man of Mystery
Re: Removing gas tank k75s
« Reply #1 on: August 04, 2025, 03:18:26 PM »
I followed this one: https://ibmwr.org/index.php/1995/08/01/gas-tank-removal/
I like silicon paste on the rubber bits so the side panels are easier to install/remove and the rubber stays pliable.  I will also mention (as someone new to bricks) that the C clips the hold the tank down have the tab pointed down, and you need the rubbers on the tank posts to pop back into the frame.  The silicone paste helped mine go back in place, but still required a strong and careful push - I focused on one corner at a time to work it in.  My Clymer manual and noting I found online was that specific so I had to figure it out after not having paid enough attention during disassembly.
Also a good time to cap and reroute the tank to crankcase line since you'll have access to the tubes under the tank.
  • '92 K75 RT / '08 GS
-Ryan
Offline Kchop
« Reply #2 on: August 05, 2025, 09:33:24 AM »
thanks for the info
  • USA
  • 1993 K75s
