Author Topic: Rate my splines?  (Read 15521 times)
Offline Los_gatos
Rate my splines?
« on: July 06, 2025, 01:00:48 AM »
Hi I was going to see if anyone could rate my splines. New to me 92 k75 63k miles. Looks like the original owner took good care of it. The guy I bought it from, not so much. I'm excited because I know final drive splines are kinda the death knell and couldn't inspect them before I plunked down money. Thanks.
  • Over there
  • 92 k75, 95 gs500
Offline Los_gatos
Re: Rate my splines?
« Reply #1 on: July 06, 2025, 01:02:54 AM »
Here's the female splines.
  • Over there
  • 92 k75, 95 gs500
« Reply #2 on: July 06, 2025, 01:31:51 AM »
8.3
Pretty good for 63k and you'll easily get another 50k and more if you keep them lubed.
Offline Los_gatos
« Reply #3 on: July 06, 2025, 01:37:17 AM »
Awesome. Thanks! I bought some TS-60 spline lube for it.
  • Over there
  • 92 k75, 95 gs500
« Reply #4 on: July 06, 2025, 02:22:46 AM »
Smart move. TS-60 the FD splines at every rear tire change and life will be good. It's probably overkill but much cheaper than replacing the drive shaft and FD. I have Scottish blood so I like to err on the side of cheapness.
« Reply #5 on: July 06, 2025, 09:09:03 AM »
Clean the shaft splines thoroughly before the application. Molybdenum bonds to surface metal; applying it over dirty splines lessens the effect of a new application.
Offline Los_gatos
« Reply #6 on: July 06, 2025, 12:41:01 PM »
Should I use chemical (brake clean)? I took a pick tool to the splines per Chris Harris. Thanks.
  • Over there
  • 92 k75, 95 gs500
« Reply #7 on: July 06, 2025, 02:20:17 PM »
You're on the right path. Lacquer thinner, mineral spirits, brake cleaner or soap and water then wipe down with a rag.
