Author Topic: Wires cut by mouse? What are these for  (Read 19010 times)
Re: Wires cut by mouse? What are these for
« Reply #25 on: April 03, 2025, 10:53:41 AM »
It's the color; it goes with almost any decor. They just can't bring themselves to eat any of it.
I'm pretty sure that most mice care more about hunger than fashion. :laughing4-giggles:
« Reply #26 on: April 03, 2025, 11:22:02 AM »
It isn't fashion they care about; it's lifestyle!
« Reply #27 on: April 03, 2025, 11:37:56 AM »
I seem to recall that rodent teeth(mice, rats, beavers) are always growing and need to be worn down by gnawing on things.  It could be that the wire happened to be handy when the need arose.
« Reply #28 on: April 03, 2025, 01:28:56 PM »
This is true. I've spent much time and effort battling rodents at my family's summer cabin. There's one spot where a bastard rat I fought with would gnaw excessively just to keep its teeth ground down.
Offline Past-my-Prime
« Reply #29 on: April 03, 2025, 08:59:24 PM »
Spies used to have a cyanide pill to use in emergency. Mice must just take what they can get.
After cleaning out an entire bale of grass from my airbox, I made a screen that goes over the intake.
« Reply #30 on: April 03, 2025, 09:05:39 PM »
It smokes and leaks oil a bit, you might be able to do something about that.
« Reply #31 on: April 03, 2025, 09:09:33 PM »
Offline gard
« Reply #32 on: April 12, 2025, 03:09:39 PM »
Update on my progress, I ordered the spal fan and cut an adapter plate from 0.082" aluminum, it is about 1" wide. I thought I might need to add a stiffener to it but it is overall about the same stiffness as the OEM fan. It is attached to the fan with 4 ea 10-32 flat head screws and nuts. I cut off the bottom arms of the original fan and used them as washers with the original screws into the radiator. The radiator hoses all look good so I decided to reuse them, hope I don't regret this.
* KIMG2717.JPG (56.68 kB . 768x576 - viewed 386 times)
The fan turns the correct direction when running power from the battery to A2 terminal of the fan switch relay socket. I am getting the correct temperature sensor resistance at both the L-Jetronic pin #10 and switch relay socket terminal E. I reinstalled the relay and shorted the E terminal to battery ground but the fan did not come on. Bad relay? No obvious burned components so I put it back together with some trepidation, started it, let it idle and the fan came on when the outside of the sensor body reached 190F. A win. The new fan draws about 2 amps.
I replaced all the fuel and vacuum hose. I replaced the intake manifolds below the throttle bodies, to answer my own question, I found this can be done without removing the fuel rail or injectors, not sure if this is the easiest. One thing I realized is I should have left the clamps loose until the air filter was installed to ensure the manifold was in the correct position. While fighting with the air filter I realized the upper grommet boots need replacing also. They looked good on the outside but there are cracks on the inside
* KIMG2714.JPG (57.55 kB . 768x576 - viewed 463 times)
I looked in 3 different auto parts stores, and finally found Gardner Bender liquid electrical tape in the local hardware store in 4 colors, it is about the consistency of neverseize, A thin coat dries in minutes, A thick coat out in the cold was hours. About the consistency of RTV when cured.  I used a couple of coats, I like it.
* KIMG2723.JPG (53.63 kB . 768x576 - viewed 360 times)
* KIMG2722.JPG (49.62 kB . 768x576 - viewed 395 times)
I have what I think is the remnants of gasket #6 (only $245 to replace). I guess this goes between the air cleaner housings, the air accumulator and the throttle bodies. But where is it located front to back on the bike? Does it go over or under the frame rails?
* KIMG2716.JPG (66.39 kB . 768x576 - viewed 372 times)
Is there some way to see the forum post photos in a preview? I use the attachments button at the bottom, insert the attachment and see some text like
* KIMG2722.JPG (49.62 kB . 768x576 - viewed 395 times) but no thumbnail or photo until after its posted, often upside down?
  • Vermont USA
  • 85 K100RT
