Author Topic: k75 crash bars set/kit  (Read 5123 times)
Offline matjas
« on: October 14, 2024, 01:57:36 PM »
Hi Guys
I have just acquired cheaply a set of k75rt crash bars. the kit seems to fit and came with ALMOST all of the mounting materials. ALMOST - I am missing the TOP parts that come at the top engine mount.
from my memory that would be a M8/M10 silentblock? can someone post a picture how this one really looks. I believe this is not available from BMW anymore.
I dont want to use a rigid mount I could fabricate as in case of some more substantial crash at any speed there might be damage to the engine block.
Do you have a picture on your hand somewhere?
Best regards
matjas
  • Poland
  • K75
Re: k75 crash bars set/kit
« Reply #1 on: October 14, 2024, 02:57:07 PM »
This part?
The original part is not available but has been superceded:
https://shop.maxbmw.com/fiche/PartsSearch.aspx?&searchtype=undefined&parts=46712303070%0A46718554872%0A
There are generic replacements available. Search for 9217K46 at https://www.mcmaster.com/
Offline matjas
« Reply #2 on: October 14, 2024, 03:55:43 PM »
Sorry. I just made a photo of what I have. I have 4 of these.
Issue is how do I attach the top of the crashbar to the engine.
In k1100 I remember there was a nut deeep inside the top of the bar so I am guessing there must have been a bolt sticking out.
  • Poland
  • K75
« Reply #3 on: October 14, 2024, 04:19:22 PM »
You need to replace the front frame-engine bolts with bolts like this:
The rubber dampers screw into those.
Offline matjas
« Reply #4 on: October 15, 2024, 03:05:22 AM »
Thanks mate. Will try to cook something like this.
Worst thing is that to fit the silentblock left/rear the silencer needs to go out. I have nothing but bad experience with touching old header studs /:
  • Poland
  • K75
Offline triplek
« Reply #5 on: March 17, 2025, 11:30:13 AM »
Are these frame anchor/bolts available from McMaster Carr - or are these proprietary and hard to source?
"Every time you criticize my grammar, I like you a little bit fewer."
1995 K75 RTP, 1995 K75 RT, 1993 K75, two K75 frames, 1 fully assembled engine from airbox to exhaust tip and enough fairings and  parts to build another K. Soon.  ;)
Offline sooprvylyn
« Reply #6 on: March 17, 2025, 01:58:45 PM »
Proprietary....you can sometimes find em on ebay or from oem parts suppliers.
  • Austin TX
Basic bitches ride Rs
