Author Topic: Sockets and cables connection  (Read 19088 times)
Offline Devl
« on: August 09, 2024, 01:50:34 AM »
Hello, i decided to refresh my bike, took it apart, repained rim, now trying to reinstal all wires and connections and there is one socket and wire that i dont now where to connect (my bad that didint marked and taked picture of it, and i didnt noticed if it was already disconnected). The wire is from battery negative cable (mine is 3in 1 cable) that goes one side to gearbox(starter negative) abd other side 3 connectors: 1 battery; 2 frame (under fuel tank); 3??? is my question.
And then i have one socket that is somwhere under the fuel tank, and its have I- kind 2 wires conection. Where to connect them ? Bike K1100RS. Thanks in advance.
  • Vilnius
  • K1100 RS
Offline sooprvylyn
Re: Sockets and cables connection
« Reply #1 on: August 09, 2024, 11:38:44 AM »
Negative terminal on the bike only needs to go from battery to the frame.  The 3 way connection is just redundancy, probably in case paint or finish prevents current from getting to parts of the bike that need ground current....like a gearbox thats painted black for example.
I dont recognize the connection style you have shown, is that connector on the same 3 way cable?  If yes, its odd that you'd get 2 leads coming from a cable that only touches ground.  Might be an accessory connector of some sort.
My k1100 only have a wire from negative on the battery to the engine block.  All the rest of the components just get their ground from the frame.  Of course my bike is a custom version, but the function is still the same for ground...as it is on all bikes.
  • Austin TX
Basic bitches ride Rs
Offline sooprvylyn
« Reply #2 on: August 09, 2024, 11:41:58 AM »
The one with the 2 prong connector may be the radiator fan wire.
  • Austin TX
« Reply #3 on: August 09, 2024, 02:55:42 PM »
According to Google Translate, the English translation of the Bayer Motorrad photo label provided by Devl is Cable set for rear brake light switch from . . ..
Offline sooprvylyn
« Reply #4 on: August 09, 2024, 03:49:52 PM »
I need to up my investigative game
  • Austin TX
« Reply #5 on: August 09, 2024, 04:41:48 PM »
Another way to put that would be to stop and smell the roses.
