Author Topic: 1990 Titan blue touch up paint  (Read 14411 times)
Offline Atabeach
« on: June 22, 2024, 03:43:56 PM »
Just a few minor scratches...does anyone know of paint that would be close...This is my rat/every day rider.
  • Ponte Vedra Fl
  • 1994 k75 Standard, 1985 k100 ( BFK 49 states) 2002 Harley’s Dyna, NEW 1999 R1100SA & my favorite 2006 Vespa LX150!
Re: 1990 Titan blue touch up paint
« Reply #1 on: June 23, 2024, 09:15:31 AM »
Take a battery cover to an auto paint store and have them match it.  Most of these places now have scanning computers that can match pretty much anything.
Offline Atabeach
« Reply #2 on: June 23, 2024, 12:01:48 PM »
That would be a last resort....I was hoping someone had the "FORD FIRE" trick for the Titan Blue..as you know...Ford fire color is a perfect match for BMW Mystic Red.
  • Ponte Vedra Fl
« Reply #3 on: June 23, 2024, 05:33:21 PM »
The Ford Fire Red was the result of having the factory Mystic Red paint scanned at my local paint shop.  If it was my bike, that is the first place I would try.  It's amazing what they can do these days.
Have them mix up up their minimum amount which is somewhere around 6-8 ounces and either have them put it in a rattle can or get a Badger model 250 airbrush like I use on eBay and a rattle can of clear coat.   That will give you enough material to do at least a couple minor repairs.  Then you will have a paint name/code you can order again when you need more.
About the Badger airbrush.  I like it because with a little bit of experimentation you can learn to blend in a less than perfect paint match on small repairs so you don't need to do the whole part with base coat.  That helps keep the material cost down and makes your touchup paint go farther.
« Reply #4 on: June 23, 2024, 08:37:40 PM »
TMG is spot on. The PPG paint matching computer is beyond science, it is MAGIC in the realm of paint matching.
« Reply #5 on: June 23, 2024, 08:43:37 PM »
