I will try that first. I have a spare bike with a relay I can salvage from it and see if that is the problem. Thanks! When it does start I can rev it up with no problem, so I cant believe its a clogged strainer. It is an intermittent electrical problem, either wiring, relay, fuse connectivity, or failing fuel pump, at least thats what i think. If replacing the relay makes no change, I will take the fuel pump and filter out, probably replace them and also inspect all the wire connections. And of course, replace the fuse.
