Author Topic: 1994 K75 Rear brakes ABS? Reservoir?  (Read 8321 times)
Offline injected59
« on: May 30, 2024, 11:13:38 AM »
Hey everyone, recently picked up a '94 K75.  Looks like a prior owner diddled with the rear brakes to get them functioning for sale.  From what I've read this bike should have ABS correct?  All that seems to be missing.  Also, I assume the reservoir is aftermarket.  Where is it normally mounted (currently zip tied).
Thanks Chris
  • Maple Park, IL
  • '94 K75 , '85 R80
Offline Lbxpdx
Re: 1994 K75 Rear brakes ABS? Reservoir?
« Reply #1 on: May 30, 2024, 11:55:03 AM »
Some folks decide to pull the ABS system, as the brain can ECU can be a bit expensive to replace.
  • Portland
  • 1994 K75S, 1992 K75RT, 1972 R60/5 & 1977 R100S
« Reply #2 on: May 30, 2024, 12:09:20 PM »
ABS was an option on the RT. Your Brick possibly didn't have it.
Your Brick not only has an aftermarket brake fluid reservoir but also an aftermarket rear brake master cylinder. It's probably from a Chinese manufacturer and is a common modification around here when the OEM Magura master cylinder fails from corrosion through lack of maintenance. The tip-off is your master cylinder's supply hose input is at the bottom of the cylinder.
The original reservoir (photo from Euro Motoelectric) is mounted into a horseshoe-shaped spring steel clip (photo from MaxBMW parts fiche) adjacent to a frame member that is concealed by the removable brake-side battery cover, or partially concealed by a low-seat panel like your Brick has.
« Reply #3 on: May 30, 2024, 01:16:11 PM »
Offline injected59
« Reply #4 on: May 30, 2024, 01:27:30 PM »
The original reservoir (photo from Euro Motoelectric) is mounted into a horseshoe-shaped spring steel clip (photo from MaxBMW parts fiche) mounted on a frame member that is concealed by the removable brake-side battery cover.
Laitch, thank you for the info.  I guess if it were the front brakes I'd be concerned.  It seems to be functioning OK, so I guess I will leave it be for now, aside from getting rid of the zip tie and permanent mount the reservoir.
  • Maple Park, IL
  • '94 K75 , '85 R80
« Reply #5 on: May 30, 2024, 02:18:36 PM »
If that's the original peg plate then your bike did not come from the factory with ABS. The peg plates for ABS bikes don't have the inverted V part (to keep passenger feet away from tire.)
« Reply #6 on: May 30, 2024, 03:51:45 PM »
Another way to tell if a K75/K100 ever had ABS is to look inside of the tail cowl. The black "wedge" of an ABS bike will have a large hole in the back of the wedge where the wiring went through to the ABS control unit. Non-ABS wedges do not have that hole.
« Reply #7 on: May 31, 2024, 01:39:04 AM »
Be aware the master cylinders are fine however the supply hose from the reservoir may be vacuum hose and can disintegrate. The end result could be brake fluid over your rear tyre.
* Reservoir Hose 1.png (35.73 kB . 768x576 - viewed 904 times)
* Reservoir Hose 2.png (38.08 kB . 768x576 - viewed 902 times)
Tags: reservoir abs
