Author Topic: New member from Northern IL, USA  (Read 13978 times)
Offline injected59
« on: May 29, 2024, 03:58:24 PM »
Hey everyone, recently acquired a '94 K75.  As long as I am here posting I am going to ask a question.  I made the same mistake I did with my airhead and removed the front wheel without checking direction.  Are these front wheels (snowflake) reversable as long as the spacers remain on the correct side?  Tire shows no indication of direction either.
  • Maple Park, IL
  • '94 K75 , '85 R80
Re: New member from Northern IL, USA
« Reply #1 on: May 29, 2024, 04:58:02 PM »
Congrats on your K.  I once mounted a directional tire the wrong way on my K75, flipping it around is perfectly fine though if the discs and pads are worn much they may have to bed in again.
« Reply #2 on: May 29, 2024, 05:28:50 PM »
If there are no arrows on the sidewall it may be possible to tell the tire direction by comparing the front and rear tire treads.
From the factory, the rotor bolts have heads on the left and nuts on the right.
When I bought my K1100RS the prior owner had it serviced by MORONS at Ventura BMW who mounted the front tire with the arrows pointing the wrong way. It trashed the tread on the front tire so the first thing I did was replace it with a new tire rotating in the correct direction.
Offline injected59
« Reply #3 on: May 29, 2024, 05:40:36 PM »
I failed to mentioned I am getting new tires. I just wanted to be able to tell my installer the direction in case it mattered. i'll go off the bolts as Franken duck mentioned.
  • Maple Park, IL
  • '94 K75 , '85 R80
« Reply #4 on: May 29, 2024, 06:16:04 PM »
Welcome to Motobrick.com!
What is the make and model of the old tires and what is the make and model of the replacement tires?
Offline injected59
« Reply #5 on: May 29, 2024, 09:09:35 PM »
The bike has old tires.  rear was a metzler and can't remember what the front is buth they were mixed .  Going with Shinkos as replacements
  • Maple Park, IL
  • '94 K75 , '85 R80
