Got around to removing the alternator and starter motor in order to locate more precisely where the oil is leaking from.
Appears to be coming out at the right of the alternator dog spinner thingy, not sure of the correct lingo here.
Assuming there's a seal behind the dog drive which after removing the dog I can just pry out and replace?
I've been searching this issue now and seems quite common. Anyone chime in before I stuff anything up.. will appreciate any hint tidbits.
Ok so I got the bolt off by jamming a piece of wood between dog and casing.
What surprised me next was that the drive dog just slid out with a bit of wiggling.. read that one needs a puller and was thinking about fabricating a custom puller and the thing just came off easily.
I can now get the seal out..
Seal popped out using a small Allen key and levering against the spline shaft and under seal.
