Author Topic: 1985 BMW K100RT won't idle  (Read 2401 times)
Offline pinhead
« on: May 03, 2024, 08:56:59 PM »
My K100 won't idle when its warmed up.  I have turned idle adjustment all the way up and doesn't help.  Any suggestions what the problem could be?
  • sacramento, ca
  • 1985 RT 100
Re: 1985 BMW K100RT won't idle
« Reply #1 on: May 03, 2024, 09:33:48 PM »
First thing I would look for is an air leak.  The crankcase breather tube(AKA "Z" tube) or the bushings above and below the throttle bodies are usual culprits.
Another possibility is a faulty coolant temperature sensor.
There is information on how to check these items here at the forum.
Offline pinhead
« Reply #2 on: May 04, 2024, 01:30:30 AM »
I changed the coolant temperature sensor a few weeks ago and no improvement.  I replaced that z tube last fall.  but no change .....
  • sacramento, ca
  • 1985 RT 100
« Reply #3 on: May 04, 2024, 04:39:52 AM »
My first guess is throttle body boot(s).
https://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/tbleak/tbleak.htm
Part 11611460408
They "only" cost $61 each these days and you want to replace all of them so you're looking at $244.
Would I pay that much? Not in a million years - because a I have both Swedish and Scottish genes trying to out-cheap each other.
The last K75 that I bought had a bad TB boot. I paid less than $30 shipped for a used set of three on Ebay - knowing that I could return them for free if I didn't like them. Turned out that they were in great shape so I gave them a 303 bath and installed them.
https://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/k75pa.rehab/k75parehab.htm#fuel.rail
Offline Bmwsquirl
« Reply #4 on: May 04, 2024, 07:28:15 AM »
For boots try a company called siliconeintakes.com
Squirrel
  • garage
  • 1995 k75rt,1974 r90/6,2020 mg v85tt
Offline pinhead
« Reply #5 on: May 04, 2024, 10:47:39 PM »
thanks all!  I am going to do that propane test for leaks and see what happens.
  • sacramento, ca
  • 1985 RT 100
