Author Topic: Fixed Fuel Level Sender, FINALLY!  (Read 9598 times)
Offline Ingo
« on: April 13, 2024, 10:16:11 PM »
Searching the interwebs I found someone somewhere used a VW sender to fix a level sender. Could not find that again. Ordered one from Amazon, slaughtered it to fix my broken one and it worked out quite well!
The "Donor" part is VW Beetle 1947-2003 : OE Number 113919049D or 113-919-049-D
Took this sender and mine apart, replaced resistor board, also resoldered the low-level switch contact, treated with Dremel and sanding disk, put everything back together and BINGO, works!
If the picts show up you can see how the resistor wire on the old one is all broken up and also what the new one looks like...
Price $ 18    vs    $280+
  • Janesville,  WI
  • 1992 K1100LT
Offline Kt88
Re: Fixed Fuel Level Sender, FINALLY!
« Reply #1 on: April 13, 2024, 11:14:38 PM »
Wow! Thank you for posting this!
  • Miami Beach, FL
  • 92 K75s
Offline blackie1
  • christchurch nz
« Reply #2 on: April 14, 2024, 02:20:55 AM »
very clever. well done  icon_cheers
  • 1991 K75RT naked 67,000kms
« Reply #3 on: April 14, 2024, 06:51:11 AM »
Very useful information, @Ingo.  I should mention that the red wire looks like PVC insulated wire.  If so, that insulation will harden, crack and disintegrate very quickly because it can't remain submerged in gasoline for long periods.  You should be using PTFE insulated wire in this application.
« Reply #4 on: April 14, 2024, 05:18:20 PM »
Just as a side note, the rubber O-ring at the base can fail to seal and leak, due to being compressed for nearly forty years. I had that problem. I replaced it with a VW O-ring. I think it was a Golf (Rabbit in the US)
Offline Ingo
« Reply #5 on: April 14, 2024, 06:01:25 PM »
The red wire is meant to be inside the tank, so i think it'll be OK, also the wire is routed such that it will not touch any metal, should be fine. Even though it's easy enough to fix later if needed.  O-ring: I i just added fuel resistant sealant. Today i installed a li-ion battery,  hopefully it's lifespan is better than the AMG I had, it only lasted 2 seasons. Did a shake down ride, 15miles, no complaints,  but need to advance timing a bit, is a bit weak at higher rpms.
  • Janesville,  WI
  • 1992 K1100LT
Offline Romonobyl
  • Probably in over my head.
« Reply #6 on: December 31, 2024, 09:22:36 PM »
I have the same situation with my decrepit sending unit. Can I ask how you got the old resistor board off it's mount? I was afraid to pry too hard as it might break, not like that would matter at this point.
I know this thread is pretty old, but thanks in advance for any input.
  • Texas Coastal Bend
  • 1986 K75S
Offline Ingo
« Reply #8 on: January 01, 2025, 07:40:13 AM »
^ - That's as good an explanation as I could do, only it's already there....
Good luck with it, should be relatively easy.
  • Janesville,  WI
  • 1992 K1100LT
Offline Ingo
« Reply #9 on: April 26, 2025, 06:20:46 AM »
BTW, by turning the wire-wound resistor board one can reverse the function of the sensor and use an aftermarket gauge...
  • Janesville,  WI
  • 1992 K1100LT
