Author Topic: fuel filter change  (Read 4200 times)
Offline pinhead
fuel filter change
« on: April 11, 2024, 04:23:16 PM »
How often do you guys change fuel filter on K bikes and where do you buy them?  thanks
  • sacramento, ca
  • 1985 RT 100
Offline John Lang
  • John Lang
Re: fuel filter change
« Reply #1 on: April 11, 2024, 05:23:30 PM »
Napa Gold 3032 every 38,000 km, if I remember to.
  • Ottawa, ON Canada
  • 1987 K75C
« Reply #2 on: April 11, 2024, 06:20:31 PM »
Ditto on NAPA 3032.
Every year or two. Sometimes before taking a long tour.
Note that's it's fairly easy to test a fuel filter. Just run the tank low, take out the fuel filter and try to blow through it in the direction of the arrow. You should be able to blow through it fairly easily.
Note that if a bike sits for an extended period the fibers in the fuel filter can swell so if reviving an old bike it's a good idea to replace it or do a test blow through it.
« Reply #3 on: April 11, 2024, 08:17:05 PM »
One bad tank of gas can plug a fuel filter.  Mine started gagging at 70mph, then 60, then 50.....
« Reply #4 on: April 11, 2024, 08:33:47 PM »
NAPA 3032 every 2-3 years.
Offline pinhead
« Reply #5 on: April 12, 2024, 02:32:59 AM »
thanks!  I will be at Napa store tomorrow!
  • sacramento, ca
  • 1985 RT 100
« Reply #6 on: April 12, 2024, 08:24:49 AM »
Don't use the hose that comes with the filter!  It's not for use in the tank.
Offline sooprvylyn
  • How else can I customize this thing?
« Reply #7 on: April 12, 2024, 03:44:06 PM »
while you are at it, you might also get yourself a fuel pump screen.  They tend to go bad over time, but they are pretty cheap and since you'll already be in the tank its worth swapping it out.  Beats having your $$$$ bosch pump break from sucking up some tank junk or pieces of a deteriorating screen.  There are 2 different screen types, make sure get the right one for your bike. My K75 had a cylindrical screen, and my k1100 has a bag type screen.  Theres a couple plastic clips on the tan retainer holding your fuel pump into the bottom of your tank that you need to depress to get the pump out.
  • Austin TX
  • '93 k1100rs last 7 of vin-6495569
Basic bitches ride Rs
« Reply #8 on: April 12, 2024, 08:34:05 PM »
There's actually there different pre-screens for K bikes. There's also a round one but without a hose attachment that was used on K100s built prior to May 85.
Offline pinhead
« Reply #9 on: April 13, 2024, 05:15:17 PM »
where can you buy these screens?  and filters also.  I checked with NAPA and they said they don't carry filters anymore.
  • sacramento, ca
  • 1985 RT 100
« Reply #10 on: April 13, 2024, 07:27:20 PM »
Filter:
WIX 33032 (I use these as well as the NAPA 3032 - basically the same)
https://www.amazon.com/WIX-Filters-Complete-Line-Filter/dp/B000C9WJBM
Screen is available from BMW:
https://shop.maxbmw.com/fiche/PartsSearch.aspx?&searchtype=undefined&parts=16121450714%0A16121455126%0A
« Reply #11 on: April 13, 2024, 07:53:17 PM »
NAPA still has them on their web page:
https://www.napaonline.com/en/p/FIL3032
Offline sooprvylyn
« Reply #12 on: April 15, 2024, 07:06:08 PM »
I honestly just get em on amazon or ebay when I need em.  Identify your prescreen shape before you order....you can often find a filter and prescreen set together.
  • Austin TX
Offline boxer.randy
« Reply #13 on: June 16, 2024, 04:16:41 PM »
Frankenduck - thanks for the tip about a fuel filter going bad by just sitting . My rarely used 75S started running poorly and pulled the old filter out with little mileage on it and could barely blow thru it. New filter and bike runs much better. Would never have thought of it. Thanks again.
  • Prescott, Arizona
  • K75S
