Author Topic: Crash bars aaaand belly pan  (Read 21316 times)
Offline Atabeach
« on: April 03, 2024, 11:03:37 AM »
So I converted a standard to an "S" by buying all the fairing goodies. The Bike came WITH crash bars, Ive since installed lights (very nicely done) ...I would have to modify the Belly pan ( severely ) to install. Anyone out there done this? Photos? Im fine leaving well enough alone...
  • Ponte Vedra Fl
  • 1994 k75 Standard, 1985 k100 ; FYK! 2002 Harley Dyna, & my favorite 2006 Vespa LX150!
Re: Crash bars aaaand belly pan
« Reply #1 on: April 03, 2024, 12:15:38 PM »
Not mine.
Offline Atabeach
« Reply #2 on: April 03, 2024, 01:07:38 PM »
Looks good but...The bars and the pan need to bar removed with every oil/filter change...unless I can split them without scratching them against the bars... Thanks.
  • Ponte Vedra Fl
« Reply #3 on: April 03, 2024, 01:41:30 PM »
Or just drill a big opening in the bottom of the belly pan.  You're already modifying it, that would just make it more practical.
Offline Atabeach
« Reply #4 on: April 03, 2024, 10:07:31 PM »
So I will be installing the belly pan and cutting in  the bars. I retrofitted a 75c into a K75S…the central clip that comes off lower radiator is used for top of belly pan…apparently. I was using this to secure the fairing grille. This leaves the fairing ( and attached grill ) without a mount in that area. Does anyone have a diagram or photo that shows correct MOUNTING of fairing? The parts diagrams do not show where mounts attach to bike…the kit that Purchased came with 2 triangular “mounts” …one of the parts diagrams shows the left fairing with a mount that I don’t have….
  • Ponte Vedra Fl
« Reply #5 on: April 03, 2024, 10:29:55 PM »
Have you viewed text, diagrams and photos starting on p. 41–11 of the BMW K100/K75 2V manual downloadable from this site?
Offline Atabeach
« Reply #6 on: April 03, 2024, 10:41:22 PM »
For some reason that would not open for me unless I put in my VIN #. Since my VIN would have been from a 75C I didn’t think it would have what I was looking for…I was looking at “Parts” guidance. Your link opened…thanks
  • Ponte Vedra Fl
« Reply #7 on: April 03, 2024, 11:00:15 PM »
For some reason that would not open for me unless I put in my VIN #. . . . I was looking at “Parts” guidance.
That's because you weren't logged in. Text links in posts are accessible regardless of whether you're logged in.
Offline Atabeach
« Reply #8 on: April 04, 2024, 08:12:02 AM »
thanks Laitch...What a fantastic resource! Ok so the clip at the top of belly pan...available? I could make one but would probably scratch the radiator grill a million times before I get it right. There is also a plastic shim? Not shown but it either supports radiator grill or keeps them from scratching each other
  • Ponte Vedra Fl
Offline natalena
« Reply #9 on: April 09, 2024, 10:49:29 AM »
Crazy as it sounds, I fiberglassed the center joint on the belly pan, and reinforced the sides with a couple stringers. Uber solid structure now, and cutting holes in it would be of little consequence. Removal is easier with the bolt holes lining up perfect. Good luck with your project.
  • MST
Offline Atabeach
« Reply #10 on: April 09, 2024, 10:55:40 AM »
That… is a great idea. Next oil change, when I disassemble. I’ll shore her up. I did drill a 1 1/4” hole for oil change when I don’t change filter.  [ Invalid Attachment ]  [ Invalid Attachment ]
  • Ponte Vedra Fl
Offline natalena
« Reply #11 on: April 09, 2024, 11:08:09 AM »
Nice dremel work! If you glass, the non-oriented mat works best, since nobody sees the finish. The woven fabric flexes noticably more, but looks great. I use West Systems epoxy. Cheers
  • MST
Offline Atabeach
« Reply #12 on: April 09, 2024, 11:47:36 AM »
That… is a great idea. Next oil change, when I disassemble. I’ll shore her up. I did drill a 1 1/4” hole for oil change when I don’t change filter.  [ Invalid Attachment ]  [ Invalid Attachment ]  [ Invalid Attachment ]
  • Ponte Vedra Fl
Offline Atabeach
« Reply #13 on: April 10, 2024, 12:51:37 PM »
* IMG_0883.jpeg (82.47 kB . 768x576 - viewed 1434 times)
* IMG_0881.jpeg (70.87 kB . 768x576 - viewed 1415 times)
  • Ponte Vedra Fl
Offline Atabeach
« Reply #14 on: April 10, 2024, 12:58:54 PM »
Ok Fellas....since I was not going to have access to my drain plug for a while I decided to do a flush and change. I DID NOT view Laitch's recommendations to add slowly. Now the fan kicks on much sooner than usual...I do not overheat and the temp light does not illuminate..... Will this fix itself? Can I massage the lower hose?....or do I HAAAAAVE to take: the crash bars and the belly pan and the fairing and the tank off....AGAIN? ugh!
  • Ponte Vedra Fl
« Reply #15 on: April 10, 2024, 03:32:37 PM »
The tank and fairing are designed so that by pulling the "C" clips at the rear of the tank with the seat up you can slide the tank back far enough to get to the coolant filler.
You will need to remove the battery covers first, and it's a good idea to put a towel between the seat and the tank when it is back to protect the paint on the tank.
Is the coolant reservoir empty?  You may be able to put coolant in it that will be pulled into the system the next time a hot engine cools down.  Fill it to the maximum mark, let the engine warm up to operating temperature, and then shut the engine down.  Check the tank after the engine cools to see if any coolant was pulled into the engine.
