Author Topic: K75 difficult to start, runs extremely rich  (Read 9391 times)
Offline bast1472
« on: March 30, 2024, 11:16:07 PM »
Unfortunately I'm back again with what appears to be another electrical gremlin, and hopefully nothing worse.
Toward the end of last year's riding season I took my K75 out for one final ride before putting it in winter storage. I noticed the battery was very weak during startup, and made a mental note of replacing it soon. I rode one of my usual scenic routes but got stuck in an unexpected traffic jam. Making matters worse, my temperature warning light came on as I was inching through the gridlock. Every time the light came on, I'd shut off the bike and walk it for a bit. Eventually I was able to escape onto a side street and get enough airflow to keep the temp light off until I made it home. A few weeks later I installed a new battery but the bike would not start. Now that the weather is improving, I'm able to do some more investigating. I can get the bike to run (like crap) if I give it some throttle, but it occasionally backfires and blows a ton of black smoke that reeks of gasoline. If I let off the throttle it dies, and I don't run it like this for long because I'm sure it's wreaking havoc on the plugs.
Based on these symptoms and other posts I've been reading, it sounds like the coolant temp sensor is bad. However, I replaced it with a new OEM Bosch unit which didn't solve my issue. I checked the temp sensor wiring inside the sheathing and from what I can see, it looks new and undamaged, but I'm beginning to suspect it might be a wiring issue rather than the sensor itself.  I also swapped in fresh plugs, new Bosch injectors, verified spark and fuel pressure, and checked that the air filter and airbox look clean. I have a spare computer that I hooked up, which had the same result.
Last season I replaced the Hall Effect sensor, so I don't think that's the issue (also those symptoms were distinctly different). I'm really hoping I didn't incur any engine damage from the brief moments it was running with the temperature light on, and the fact that it will fire up and run (albeit rich) gives me hope that's not the case. The overheating was a shock because I'd flushed the coolant and bled the system within the last year, and I've never had any cooling problems before, even in hot weather with lots of clutching. I'm thinking of acquiring a replacement sub-wiring harness but at this point I'm just throwing parts at it. Hoping to get your thoughts and recommendations on how to proceed given the details above. Thanks in advance!
  • Seattle
  • 1995 K75
Offline caveman
Re: K75 difficult to start, runs extremely rich
« Reply #1 on: March 31, 2024, 04:26:53 AM »
may want to check the air vane in air intake box?
  • Kennerdell, PA.
  • 87 K100RT, 88 K100LT
« Reply #2 on: March 31, 2024, 08:54:48 AM »
I was shocked to see a gun barrel in my face because I only had five dollars in my wallet and I had never been robbed before.  :laughing4-giggles:
∆. Follow caveman's suggestion. The vane should swing without sticking.
1. Grasp the fuel injection control unit plug by its left end. If you can swing it outward to the right without moving its latch, it has been partially disconnected and likely the source of your difficulties
⊛. A Brick engine can handle the interval of overheating you've described; stay calm.
⚧. Use a slender dowel to rotate the fan's blade assembly. If it doesn't rotate easily, there's part of your overheating problem. You    probably should check to determine if the Hall effect sensor assembly you installed has loosened and rotated out of alignment.
B. Tell us from where you purchased the temp sensor and give us its part number.
♋︎. With the engine cold and the ignition switch set to Off, set your multimeter to Ω and use its leads to connect socket 10 and socket 13 of the fuel injection control unit plug. Tell us the resistance. 2.5K Ω would be good but the range ok if a bit higher.
✿. Don't throw parts at it. Test for function.
Offline stokester
« Reply #3 on: March 31, 2024, 03:23:44 PM »
Yes, take it one step at a time for a diagnosis and keep a running log on what you find.  We're not dealing with a CAN bus and there is good advice here to ensure you don't spend any money unnecessarily.
  • Yorktown Virginia
Offline bast1472
« Reply #4 on: March 31, 2024, 11:21:30 PM »
Thanks all for the tips. I still need to check out the vane and HES but here's what I was able to check today:
1. The fuel injection control unit plug is tight and doesn't swing loose without releasing the metal latch.
2. The radiator fan rotates freely.
3. The temp sensor is from Euro MotoElectrics, Bosch part # TEMPSENS-K197O (https://www.euromotoelectrics.com/TEMPSENS-K197OE-p/tempsens-k197oe.htm). Prior to this one I had been running an EnDuraLast temp sensor from the same retailer, part #TEMPSENS-K197.
4. My multimeter shows 3380 ohms across sockets 13 and 10.
This week I'll check that the Hall Effect Sensor has not moved, and dig into the airbox to see if the vane is stuck. By the way, I replaced I replaced the HES two seasons ago with an EnDuraLast K049EDL from EME.com. Before replacing it, I was having another starting issue where the bike would only run (like crap) with the computer unplugged.
  • Seattle
  • 1995 K75
« Reply #5 on: April 01, 2024, 12:17:21 AM »
What fuel injectors did you install?
The fan should spin up if you put 12V to the A2 pin of the temp relay socket. (Pin layout is printed on the temp relay.)
As noted, the temp light coming on isn't a big deal. Similar to a car, after the warning comes on, when it gets even hotter the radiator cap will blow (and get your left foot all wet) before there's any engine damage.
Offline bast1472
« Reply #6 on: April 01, 2024, 12:40:33 AM »
The latest fuel injectors I installed are these EnDuraLast ones from EME: https://www.euromotoelectrics.com/product-p/finj450edl.htm
Good to know about the radiator cap and the fan test, I'll verify that it still functions. Thanks.
  • Seattle
  • 1995 K75
« Reply #7 on: April 01, 2024, 01:15:44 AM »
I meant right foot, not left, for radiator cap blow.
The power wire to the fan at A2 is violet yellow.
Do you know the Bosch part number of the fuel injectors? It shows on the side. It's probably impossible to see with them installed though.
Here's an example of a stock K75 injector:
« Reply #8 on: April 01, 2024, 02:04:50 AM »
According to the EME link bast supplied, the Bosch part number is the same as you indicated in photo.
« Reply #9 on: April 01, 2024, 02:39:02 AM »
The same page says that the original 210 FI is discontinued. The only way to know is to inspect what one has in hand.
« Reply #10 on: April 01, 2024, 09:13:41 AM »
That reading sounds like the sensor's normal resistance of ~2400ohms added to the resistance of ~1000ohms in the ground connection.  That looks like a very cold engine to the Jetronic causing it to make a very rich mixture after the engine warms up.  My suspicion is that there may be a bad electrical connection between the temperature sender and the stub and/or between the stub and the engine block.
What is puzzling is that you are reading a thousand ohms between the connector pin #13 and the engine block.  That should be close to zero, and could be causing a bunch of other weirdness in the operation of the engine.
Last, have you checked the zero on your meter???
« Reply #11 on: April 01, 2024, 10:36:20 AM »
That goes for just about everything bought online.  :laughing4-giggles: The idea attempting to be conveyed in the text is likely to be that the injector is a replacement for 210 with the same characteristics as 210—somewhat on the line of EME replacement fuel sender, the oem version also discontinued. The only way to know first hand beyond inspection of the injector is to test the flow rate, impedance and other submagical stuff.
« Reply #12 on: April 01, 2024, 11:54:34 PM »
The best way to know the specs for a given fuel injector is to know the manufacturer part number that is printed on it and check the data sheet for that product. There is nothing magical nor even "submagical" about it. What does the word submgical even mean?
« Reply #13 on: April 02, 2024, 07:31:49 AM »
Below magical :laughing4-giggles:
Offline Past-my-Prime
« Reply #14 on: April 02, 2024, 10:40:49 AM »
Sometimes things work and even the engineers don't know exactly why. It may or may not be magical. It could also be substituting for magical. That's how I interpreted it!
Offline bast1472
« Reply #15 on: May 15, 2024, 07:47:09 PM »
I wasn't fully trusting the readings on my $10 meter, so I finally got around to getting a nicer one. However, now I'm getting no reading ("OL" / open loop) measuring resistance across 13 and 10. I measured resistance from the temp sensor plug and one of the wires gets 0.0 resistance to port 10, the other sensor wire reads 0.0 at the plug to the temp sensor relay. I cleaned up all the ground connections mounted to that point under the gas tank to make sure they're all shiny/bare metal but it didn't change any of these readings.
I looked at some wiring diagrams available on this site and it seems port 13 should be grounded to the frame under the gas tank. I checked resistance from port 13 to the ground bolt and it reads 0.0 resistance. I also checked resistance from port 13 to the lower battery ground bolt and that also reads 0.0.
I swapped the temp sensor relay for a spare I have, which made no difference in the open loop between ports 10 and 13.
I also plugged the temp sensor plug into a couple different spares I have, but they all result in an OL reading between ports 10 and 13.
Finally, I checked all the fuses in the fuse box and they all had continuity.
Are there any other grounding points I should be checking, aside from the one under the gas tank and the one under the battery on the left side of the frame?
  • Seattle
  • 1995 K75
« Reply #16 on: May 15, 2024, 11:02:12 PM »
The temp relay has no impact on the reading at pin 10. Pin 13 is ground.
The coolant sensor is a dual sensor with two wires - one wire goes to pin E of the temp relay and the other wire goes to Pin 10 of the L-Jetronic. You can use any ground or Pin 13 for the other ohmmeter lead.
The temp sensor grounds via the threads.  To measure an uninstalled temp sensor you measure from one terminal or the other to the metal body of it.
See green lines in this diagram:
« Reply #17 on: May 15, 2024, 11:40:12 PM »
With the multimeter turned On, did you touch the red and black probes together in the Ω setting before testing?
What is the resistance between 10 and 5?What is the resistance between 5 and 13?
Offline bast1472
« Reply #18 on: May 16, 2024, 01:49:35 AM »
Laitch -- I get 0.0 when touching the meter's red and black leads in Ω mode, and OL when they're not touching. The resistance between 10 and 5 is OL, and the resistance between 5 and 13 is 0.0.
  • Seattle
  • 1995 K75
Offline bast1472
« Reply #19 on: May 16, 2024, 02:08:04 AM »
Frankenduck -- I've tried two different sensors (off the bike) and I cannot get a reading, only open loop, probing either blade with one probe, and the threads/brass body with the other probe.
  • Seattle
  • 1995 K75
« Reply #20 on: May 16, 2024, 02:12:06 AM »
Measure the resistance between pin E of the temp relay socket and ground. VIO/GRN wire.
When you replaced the temp sensor did you have the wire clip on the connector? (Similar to the fuel injectors.)
On my K100 a previous owner had forgetton forgot that and the connector eventually fell off of the temp sensor.
« Reply #21 on: May 16, 2024, 02:14:38 AM »
What's the name/model of your multimeter?
Offline bast1472
« Reply #22 on: May 16, 2024, 02:29:51 AM »
Frankenduck -- I'm getting infinite resistance between pin E of the temp relay socket and ground. Yes, my sensor has the wire clip (which is an annoying PITA to release, but it is there), and I've always reinstalled them correctly to keep any plugs from backing out. My new meter is a Klein MM420. It is a little curious that my old meter was showing a resistance reading between 10 and 13 and this one has only ever shown OL. Unfortunately I already gave the old cheapo one away.
  • Seattle
  • 1995 K75
« Reply #23 on: May 16, 2024, 02:43:47 AM »
Does it beep when you touch the red and black leads together?
From pics of it it looks like the ohms position has two functions:
1 - Audible continuity tester
2 - Ohms
I think to get it in ohms mode that you need to turn it on to the second to the last on the right setting and then hit the SEL button to get it into ohms mode.
Offline bast1472
« Reply #24 on: May 16, 2024, 02:47:39 AM »
Yeah, it beeps when I touch the red and black leads together. I just looked at the instruction manual and saw that it defaults to continuity mode, which still seems to show ohms when resistance is measured, but I went back anyways and re-tested everything in ohms mode. The results were the same ¯\_(ツ)_/¯
  • Seattle
  • 1995 K75
